All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-23-2011, 03:30 PM
bart_dood bart_dood is offline
Junior Member
Default How to add 3 phase currents for total?
Hi Folks,
I am working on a 3 phase motor controller, one each phase leg of the motor I have current sensors, they are transformer coupled and nominally float at 2.5 volts, they then swing between 0 volts and a maximum of 5 volts as they detect the alternating current flowing through.
The scaling is something like 85amps for 1 volts.
What I'm trying to do is get the total current value. From what I understand I should add all three current values together in my microcontroller, this should equal the total current.
Of course I'll have to do some stuff on my microcontroller to do this, first of all subtract the 2.5 volt offset from each sensor, then remove any negative signs, then multiply the voltage by the 85 scalar and then add them all together.
Does this make sense?
  #2
Old 03-23-2011, 11:23 PM
Junior Member
Default Another image
Here is what I'm talking about adding, the green lines represent the instant currents at one point.
So the absolute values of 1, 2 and 3 would be added together.
  #3
Old 03-24-2011, 08:46 AM
eblc1388's Avatar
eblc1388 eblc1388 is offline
Default
Quote:
No. Ever heard of vector sum?
The vector sum of all three phase current in a balanced load is always zero.
There is no total current for a motor as currents vectors are not in phase but 120 degree apart. It is common to use line current value of one phase to specify the current of a motor.
__________________
L.Chung
  #4
Old 03-24-2011, 06:42 PM
Junior Member
Default
But if I take one phase and read it as the current, it will be going up and down? I thought the whole point of 3 phase systems was that the current load is effectively constant, eliminating ripple and increasing efficiency?
  #5
Old 03-27-2011, 02:34 PM
Junior Member
Default Use RMS chip
I had the idea of using an off the shelf RMS to DC analog chip, I would input one of the phase voltages and read the DC output with my microcontroller.
Would this work?
  #6
Old 03-28-2011, 01:52 AM
Junior Member
Default Ok I think I got it now
From reading online it seems the DC component of the 3 phases is the sum of the squares, so I just square each current and add them together.
Can anyone confirm this is correct?
  #7
Old 03-28-2011, 04:14 AM
t_n_k t_n_k is offline
Default
Probably incorrect.
What do you mean by DC component? You seem to have some mistaken ideas about AC.
If the phase currents to the AC motor are balanced, then the instantaneous current summation is zero - as eblc1388 has pointed out. There is normally no DC current in an AC motor fed by a 3-phase mains supply.
If you want the power input to the motor, then the 3-phase input power under balanced conditions would be
Pin=3xVrmsxIrmsxcosθ
Where Vrms and Irms are the phase voltage and current and θ is the phase different between the voltage & current waveforms.
Again as eblc1388 already suggested you would typically use a current measurement on one of the motor phases to monitor current and assume the other phases are equal in magnitude.
You could certainly use an RMS to DC converter to obtain a simple measurement of the motor line current(s). One might measure all line currents where the dynamic control of an AC motor requires extremely tight control of performance or where motor protection is critical, and so on. This would typically be of interest in a variable speed drive (VFD) system.
  #8
Old 03-28-2011, 04:31 PM
Junior Member
Default
Quote:
Originally Posted by t_n_k View Post
Probably incorrect.
When I talk about DC component I'll explain a little more.. my system is a set of batteries driving a 3 phase inverter that drives a brushless permanent magnet motor.
On each phase leg between the inverter and motor there are current sensors (essentially little transformers around the phase legs) that pick up the current flowing through each leg as an AC waveform, I am in the process of figuring out the scale, IE how many volts output from the sensor equates to amps in the leg.
I am designing an LCD readout which has all the various parameters on it and to calculate power used I need the current draw. I will have a real time reading of the battery voltage, so once I have the current draw I'll simply multiply the voltage by the current.
Of course the inverter is not 100% efficient so the DC side will be slightly higher power draw, I can actually calculate this real time as I track the efficiency based off a look up table.
I could add a shunt resistor on the battery side and design a circuit to read in the voltage drop and equate it to current, however this adds more electronics and there are a few other reasons I'm trying to avoid doing this. It should be possible to use the 3 phase currents to calculate this, once I have the scalar (volts to amps).
Tags
Related Site Pages
Section Title
Worksheet Delta and Wye 3-phase circuits
Worksheet Rectifier circuits
Worksheet Superposition theorem
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet AC power
Worksheet Mixed-frequency signals
Textbook Harmonics in polyphase power systems : Polyphase Ac Circuits
Textbook Series resistor-inductor circuits : Reactance And Impedance -- Inductive
Textbook Kirchhoff's Current Law (KCL) : Divider Circuits And Kirchhoff's Laws
Textbook Simple series circuits : Series And Parallel Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Phase shift of a sinusoidal signal Enforcer83 The Projects Forum 3 03-21-2011 10:53 AM
current phasors Sparky General Electronics Chat 7 02-08-2011 04:50 PM
Three phase induction generator on a single phase supply dec335 The Projects Forum 4 10-13-2010 11:34 AM
Three phase vs single phase rectifier questin DiBosco General Electronics Chat 5 09-09-2010 01:39 PM
Power Engineering Help (Star-Delta) mksa Homework Help 2 05-09-2006 05:41 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
