Hi there,
My name is Sina, 25 from Iran. I've been interested in this induction heating thing and would like to build one. Its quite a long time searching the net and experimenting to make it work.
I've been stuck with the pll issue. My configuration is Hbridge which is fed from a simple power supply(not split) so the lowest point is ground. The two signals I try to maintain a phase lock of 90 degrees are the Inverter voltage and tank cap voltage. The inverter voltage is fed from pin 4(VCO out) to pin 3(COMP in) of 4046 as inverter voltage representative. But in order to get a square wave as a representative of cap voltage I'm trying to use a voltage comparator lm393. My question is how to connect lm393 across the cap and meanwhile protecting its inputs from excessive voltage that appear across the cap?
I tried to put a shunt resistor in series with LC tank and use the voltage drop across it as an indicator of inverter current phase angle but the voltage across it is very odd in its shape and if converted to square wave does not show the phase angle of the inverter current.
Also I am very interested to use the phase comparator 2 of the 4046, this phase comparator tries to lock zero angle between its input signals which is alright if I was able to use the voltage across the shunt resistor. but in this case I should change the phase angle of the cap 90 degrees and then try to lock zero angle between it and the inverter voltage.
Any help, suggestions and schematics would be very welcomed. Please let me know if I should send schematics or if my explanations are not complete also I can be available for a chat at any time if this would be an easier way for anyone to help.
Thanks in advance.
Best Regards
Sina
Thanks in advance.
Best Regards
Sina
