All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Embedded Systems and Microcontrollers
Notices
Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-08-2007, 06:44 PM
hammy hammy is offline
Default Interfacing a microcontroller with a PC using serial port
Hi friends,
I'm doing a project on data acquisition where i need to interface an ADC with a microcontroller and then this microcontroller with a PC where in the values are to be displayed.
The first part is finished but i have very little idea about interfacing 8051, which i'm using with the PC. I know C language
(alas! never did microcontroller programming) and have 10 days time in my hand to learn and implement. I need to develop the code where in the data obtained is displayed on the PC in real time. I'm planning to go for RS232 communication using MAX 232 IC.I'm using the 89c51 IC.
I'd be grateful to anyone who can help me with this.
  #2
Old 03-09-2007, 03:35 PM
beenthere's Avatar
beenthere beenthere is offline
Default
1. Tell the ADC to convert.
2. Get the number from the ADC.
3. (optional) Convert or scale the number to engineering units.
4. Send the data to the MAX233, which should then be set up to transmit to the PC.
Look for example porgrams the work with ADC's and that send serial data.
  #3
Old 03-10-2007, 07:45 AM
jasonhaykin jasonhaykin is offline
Junior Member
Default
http://mcu-programming.blogspot.com/...terfacing.html
check this page.
  #4
Old 03-13-2007, 09:08 AM
Default Serial interface is what is needed!!!
Thank u friends for the replies ...as i have said the interfacing of the ADC with the microcontroller is finished....
The problem is interfacing the microcontroller to the PC and display the data transmitted from the 89C51 (which i'm using) on the monitor...
  #5
Old 03-13-2007, 02:41 PM
beenthere's Avatar
Default
You may need to investigate serial I/F chips, like the MAX232. There are many available.
  #6
Old 03-15-2007, 09:58 AM
Arm_n_Legs Arm_n_Legs is offline
Default
Interfacing microcontroller to the PC? Thought you have mentioned using RS232 communincation. Just hook up the 8051 Tx pin to the Tin of the MAX232 and the Rx pin to the Rin of the MAX232. Connect these to pin (2) and (3) of the PC D-9 connector.
  #7
Old 09-15-2011, 09:03 PM
Pete77 Pete77 is offline
The following site provides a circuit to interface a microcontroller to a PC using just basic parts available from Radio Shack. Furthermore, the circuit presented does not require an external power supply. If interested, the url is:
http://sites.google.com/site/calculatingrisk/Home/--serial-port-interface
  #8
Old 09-20-2011, 11:18 PM
nicsnicolan nicsnicolan is offline
Junior Member
Default
sir just wanna ask how did you able to interface the adc to the microcontroller??
Tags
Related Site Pages
Section Title
Worksheet Shift registers
Worksheet Digital communication
Worksheet Digital display circuits
Video Lecture Hardware: IO, RTC, PS - Microprocessors
Video Lecture Representative System (Part 2) - Computer Hardware - Microprocessors
Video Lecture Representative System (Part 3) - Executing a Program - Microprocessors
Video Lecture Hardware - Memory - Microprocessors
Video Lecture Microprocessor bus Networks - Microprocessors
Textbook Networks and busses : Digital Communication
Textbook Introduction : Shift Registers
Similar Threads
Thread Thread Starter Forum Replies Last Post
matlab and arduino: serial port connection lcr2139 Embedded Systems and Microcontrollers 2 04-08-2013 06:28 PM
Parallel Serial Port problem ssembo The Projects Forum 5 07-05-2011 09:50 PM
appliances management using interfacing of VB6.0, PIC16F877, and parallel port marcus jamus Embedded Systems and Microcontrollers 1 06-30-2009 01:18 PM
Working with serial port auststud Embedded Systems and Microcontrollers 2 05-06-2009 03:15 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
