All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 03-03-2007, 09:36 AM
Steve1992 Steve1992 is offline
Default Basic Single Tuned Amplifier
With ref. to attached circuit, am I right with the following statement?:
1. Amplifier load is a parallel resonant circuit.
2. Tuned to give high Z at the selected frequency, by varying C1.
3. At resonance, the current is a minimum, Voutput will be large:
Voutput = VDD - Voltage across L1,C1.
Steve
  #2
Old 03-04-2007, 03:14 AM
Ron H's Avatar
Ron H Ron H is offline
E-book Developer
Default
You're basically right, but in (3), do you think the output amplitude is a function of the input amplitude?
  #3
Old 03-04-2007, 10:38 AM
Default
Thanks Ron.
The circuit is a basic A.F. amplifier - instead of a load resistor at the drain, there is the cap. Ind. parallel combination.
So the A.F. amp. calculations can be used:
Vouput = Vdd - Voltage across resistor.
  #4
Old 03-04-2007, 02:46 PM
Ron H's Avatar
E-book Developer
Default
Quote:
Originally Posted by Steve1992 View Post
Thanks Ron.
Yeah, but doesn't the output also swing above Vdd?
Since you posted this under homework help, I'm assuming that's what it is, so I'm being coy.
  #5
Old 04-22-2008, 04:32 PM
narayanbalaji narayanbalaji is offline
Default
hi,
can u pls say me the advantages and disadvantages of single tuned n double tuned amplifiers..
  #6
Old 04-22-2008, 04:43 PM
Caveman Caveman is offline
Default
narayanbalaji,
Why didn't you just start your own thread?
Tags
Related Site Pages
Section Title
Worksheet Passive filter circuits
Worksheet Resonance
Textbook Frequency and phase measurement : Ac Metering Circuits
Textbook Resonant filters : Filters
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Resonance in series-parallel circuits : Resonance
Video Lecture JFET Amplifiers - Transistors and Transistor Circuits
Textbook Input and output coupling : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook Diode switching circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
single stage amplifier nebula_fairy Homework Help 4 08-18-2011 09:18 AM
Operational Amplifier circuit2000 Homework Help 4 02-21-2007 04:39 AM
My PC amplifier problem....? k41 The Projects Forum 2 12-15-2006 06:07 AM
audio amplifier project revolver The Projects Forum 1 11-23-2006 09:30 PM
your "Common Base" amplifier page is wrong Viper Feedback and Suggestions 7 10-21-2006 09:56 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
