All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-28-2007, 06:43 PM
star star is offline
Junior Member
Default Applications for the monostable multivibrator
Hi there,
I understand that the monostable multivibrators are used to hold output voltages in its unstable state for a certain period of time regardless of how long the triggering waveform is held high/low, as well as being used for rising/falling edge detection in flip-flops.
However, how can I relate the importance of the monostable multivibrator to applications with more significance/meaning to day-to-day life?
Any ideas would be appreciated.
  #2
Old 02-28-2007, 06:53 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
There use was more prevalent in the distant past. Now they are largely forgotten since we can clock logic at much higher speeds then we could in the 1960's. In my 45 years of hardware design experience I've never had occasion to use one.
The main problem with them is that although the leading edge is syncronous after a small and predictable delay from the trigger, the trailing edge is not. It depends on the actual values of an R and a C somewhere. The pulse width is not tightly controlled, but wanders all over the place.
  #3
Old 02-28-2007, 06:57 PM
Junior Member
Default
Oh okay... I didn't realise the technology was so old..
Which technology is in use now for clocking?
  #4
Old 02-28-2007, 07:20 PM
Papabravo's Avatar
Default
I think you might misundertand. A clock is derived from an oscillator or astable multivibrator. This device has no stable states and continually switches back and forth between two states.
The flip-flop has two stable states and is also called a bistable multivibrator.
Review:
astable -> no stable states, an oscillator
monostable -> one stable state, a one-shot
bistable -> two stable states, a flip-flop
BTW - what replaces a one-shot is a counter or a shift register which is clocked very much faster than the process being controlled. In this way both the leading and trailing edge can be precisely positioned.
  #5
Old 02-28-2007, 08:02 PM
Junior Member
Default
Okay, I understand that now.
I'm still confused about the one-shot though.. where is it, or in the present-day, the shift register used, in terms of real world applications?
  #6
Old 02-28-2007, 09:10 PM
Papabravo's Avatar
Default
The main place it would be used is to stretch a narrow pulse into something longer. For example if you have a 1 microsecond pulse and it needs to be 4 microseconds long then a one-shot or a shift register can accomplish this function.
  #7
Old 02-28-2007, 11:09 PM
Archiebold Archiebold is offline
Send a message via MSN to Archiebold
Default
I actually used one of these in the recent past for a magnet switch debouncer. Once the 555 goes high, the switch could go on and off several times withing that short (milliseconds?) period of time. Without the monostable, it would be pulsing each of those several times. I used the output of the monostable to feed my clock pulse on a counter.
Just my $.02
RJ Vandermate
  #8
Old 02-28-2007, 11:21 PM
Papabravo's Avatar
Default
Quote:
Just my $.02
RJ Vandermate
In this case each of the input pulses retriggers the one-shot whose output looks like a single long pulse.
__________________
We never have time to do it right,
But we always have time to do it over.
  #9
Old 02-28-2007, 11:25 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
The main reason that multivibrators were banded on designs at the company where I work was that while the pinouts for a given device with the same root part number were the same across manufacturers; the equation for computing the pulse width from the resistor and capacitor timing components tended to vary between manufacturers.
This frequently resulted in boards that failed to function properly because some vendor convinced a purchasing employee that the parts were identical. Safeguards were put in place but the occasional incompatible part would make its way into the board production run.
hgmjr
__________________
"No human being should be allowed to have this much fun."
hgmjr
May we never lose compassion for those who need our help and encouragement.
  #10
Old 02-28-2007, 11:34 PM
Papabravo's Avatar
Default
Quote:
Originally Posted by hgmjr View Post
.... the equation for computing the pulse width from the resistor and capacitor timing components tended to vary between manufacturers.
Not to mention the various environmental factors that effect pulse width like temperature, supply voltage, and the phase of the moon.
__________________
Tags
Related Site Pages
Section Title
Worksheet Timer circuits
Worksheet Design Project: Logic probe
Textbook Monostable multivibrators : Multivibrators
Textbook Edge-triggered latches: Flip-Flops : Multivibrators
Textbook The gated S-R latch : Multivibrators
Textbook The S-R latch : Multivibrators
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION BLUE LED FLASHER : 555 Timer Circuits
Textbook CMOS 555 LONG DURATION MINIMUM PARTS RED LED FLASHER : 555 Timer Circuits
Textbook 555 MONOSTABLE MULTIVIBRATOR : 555 Timer Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Monostable Multivibrator xxbleh General Electronics Chat 4 03-04-2012 03:40 PM
modify 555 one shot monostable multivibrator circuit steven334 The Projects Forum 12 08-25-2011 01:42 PM
555 monostable multivibrator circuit steven334 The Projects Forum 14 08-25-2011 05:13 AM
Feedback on 555 Monostable Multivibrator allenpitts Feedback and Suggestions 4 06-06-2011 04:30 PM
Monostable Multivibrator ChemEnger The Projects Forum 5 10-08-2009 10:54 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
