All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-10-2011, 09:43 AM
ph88 ph88 is offline
Default USB Sniffer
Hi!
I'm a student in electric engineering, for my internship my employer requested me to make an USB sniffer. I've been keyboard-jockeying for days now, looking at datasheets, specifications and models.
A short introduction for the ones who are not so familiar with USB.
USB has four wires: gorund, Vbus, D- and D+.
De data is provider bij D- and D+. The differential of the two respresents the data. The data is encoded with NRZI. A 0 will make the signal flip sign and a 1 will keep the same signal level. If a 6bits of 1 are sended an additional 7th bit (0) is send to make the signal flip. Adding this dummy bit is called bit-stuffing and is used to keep the clocks of the host and client in sync. The clocks are generated from the data signal.
When the signal is received the NRZI is decoded and bitstuffing removed. Then the controller will detect the USB pakket start (start with a synac field). The packets are buffers which are called endpoints.
CRC is applied to the packets to maintain data integrity. When an error is detected this will be flagged and the corrupt packet will be discarded.
From the endpoints on the software will take over. The software will address the Host Controller Interface. They used to be of type OHCI or UHCI, but nowadays EHCI is used. All modern operating systems come with a Host Controller Driver (most of the time in the kernel).
De the USB host (master) always start with communicating when it detects a newly connected device by measurement of voltage/impedance. The USB host sends the client a request to indentify itself, this information is called the USB descriptors. Then normal data transfer can proceed.
Linux Kernel 2.6 will write the descriptors to "/proc/bus/input/devices" en the data to "/dev/xxx", where xxx represents the device.
The customer would like informatie of all levels of the USB-connection (a bit similar to the OSI model).
A. Physical (electrical signals)
B. The bitstream (which is just the differential between D- and D+)
C. The USB packets
D. The USB descriptors and the USB data
The goal is that the measurement is done on the kabel between the host and the client (like a pc and mouse).
A PCB for this purpose could look like this:
Or like this:
Because of the limited time and the complexcity of an USB controller i'd rather not design one myself. But i do want the packets which are usually discarded by regular USB controllers. Usually only a flag is set when a corrupt packet is detected, but it doesn't indicate in which bit the error was found.
The idea is now to connect an USB controller as well as an USB probe to the probing-point
This would look like this:
The USB probe is supposed to gather information about A, B and C. The controller about C and D.
I assume the USB probe won't drain too much current because of the high input-impedance. But i expect the usb controller to drain a significant amount and mess up the signal. So i need some kind of analog buffer that preserves the signal. I was thinking in the direction of operational amplifiers. This should go somewhere in the area located with the red circle.
Additional information:
* I would like to support USB 1.0 (low-speed), USB 1.1 (full-speed) and USB 2.0 (high-speed).
* The USB probe would be a osciloscope with USB interface and without display. I haven't investigated yet if there are USB scopes/probes with a sample rate high enough for 480 Mbit/s
My question is: am i going the right way with my solution?
Especially about the analog part (red circle), but any suggestions or comments are very welcome!
Thanks!
  #2
Old 02-10-2011, 02:47 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
There is nothing that says you need to draw power from the USB power pair. In fact I would advise against it.
Operational amplifiers that work on USB High Speed may be difficult to work with at 480 MBis/sec. I would tend to look more for a chip with a specially designed USB transceiver. There are several analyzers out there so the project is doable, but at what expenditure of time and dollars. I like the cost effective ones from Total Phase
$400.00 for the USB 12 Protocol Analyzer. For High Speed (480) the price triples -- gee I wonder why?? Could it be the difficulty of making things work at those speeds.
__________________
We never have time to do it right,
But we always have time to do it over.
  #3
Old 02-10-2011, 02:54 PM
wayneh wayneh is offline
Default
I think "all" you need is a data acquisition device. On the low price end (50-120$) are devices like the LabJack. (I have one and love it). But I don't think it can handle the speed you need. It IS capable of "stream" mode, but still.
The more you pay, the faster these things get. You can buy a card, stick it in your PC, and have GHz capture capabilities.
  #4
Old 02-10-2011, 03:49 PM
CDRIVE's Avatar
CDRIVE CDRIVE is offline
Default
Quote:
This really an interesting topic. It beats the pants off endless LED topics, so I don't want to hijack it. Quick question... Is Labjack compatible with VB6.0?
__________________
__________________________________________________ ___________________________
Disclaimer: Any information that I post is intended for educational purposes only. No warranty or liability is expressed or implied. Note: Working with household line voltages (Mains) can be dangerous. Proceed at your own risk!
  #5
Old 02-10-2011, 04:40 PM
blueroomelectronics's Avatar
blueroomelectronics blueroomelectronics is offline
Default
If the PC is the host you can get USB protocol sniffer software.
__________________
Bill
  #6
Old 02-10-2011, 11:02 PM
Default
Quote:
Without knowing anything about VB6, I'll say yes simply because the LabJack is pretty much compatible with anything. I talk to mine via Visual Basic in Excel, since that's where I analyze my data and it's what I know. I know I can also get at it with XCode (Mac OSX object oriented C++ I think), using Terminal commands, and many other ways. Any language that can read/write files can talk to it, although streaming may not work with that approach. Works fine to 5Hz or so, or slower.
  #7
Old 02-11-2011, 03:22 AM
CDRIVE's Avatar
Default
Thanks for the info.
__________________
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
USB Network timyhac The Projects Forum 6 03-20-2010 05:34 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
