how to drive a capacitor with thyristor or triac
Status
Not open for further replies.
mesuthh
Joined Jan 17, 2011
8
Hello People;
I am trying drive 25uf capacitor with a optocoupler and triac. I have tried so many triacs and huge heatshinks, but always triacs goes fire because the high temperature on triac.
is there any advice
thanks from now on
regards
Adjuster
Joined Dec 26, 2010
2,148
Please explain in more detail, and post a schematic of your arrangement.
I advise you not to try it again before finding out what is wrong, as it sounds dangerous - is the circuit connected to the mains?
t_n_k
Joined Mar 6, 2009
5,455
mesuthh,
you didn't fully answer the question about the supply voltage.
Your triac is probably failing due to exceeding a critical parameter value.
The single or repetitive peak current may be an issue. There are transient as well as steady state conditions to consider at the turn-on instant.
You might consider placing a limiting load resistance in series - such as an incandescent lamp - to make sure the basic function is what you intend.
What is the point of your experiment?
GetDeviceInfo
Joined Jun 7, 2009
2,273
mesuthh,
Your so kind.
I would have said, your shorting your supply out moron, your going to injure yourself or someone else.
mesuthh
Joined Jan 17, 2011
8
mesuthh,
dear Tnk I am trying to make a mini compansating
regards
beenthere
Joined Apr 20, 2004
15,819
That circuit is not going to "drive a capacitor", but demonstrate the sensitivity of a TRIAC to ΔV/ΔT and/or short circuit current.
What is the AC source? Is the capacitor rated for AC? Why is there no fuse present?
Adjuster
Joined Dec 26, 2010
2,148
I would guess that this is an attempt at switching power factor correction capacitors. That is actually a pretty tough application: professional gear of this kind goes to some lengths to protect the switch elements. This circuit has no snubbing or other filter elements: apart from the inherent switching rate problems, any spikes or higher frequency cr*p on the mains input can come straight through the capacitor to get at the triac.
The drive to the input LED comes via another unspecified LED in series, so it's not clear how much drive it would get.
There may however be a far more basic problem. When the LED drive is removed, the triac will turn off when the capacitor current drops to zero. This is however on the peak of the input voltage, when the capacitor will be fully charged. When the input voltage reverses, the capacitor voltage will be added on to the next voltage peak, giving a total of about 678V for a 240V AC supply. This may be enough to break over the triac, in which case it will surely fail.
mesuthh
Joined Jan 17, 2011
8
dear beenthere;
AC is 240 V Ac.
regards
beenthere
Joined Apr 20, 2004
15,819
The circuit as posted is not going to work under any circumstances.
Perhaps the OP can explain what he means by "driving a capacitor", and why there are no fuses present.
Adjuster
Joined Dec 26, 2010
2,148
dear beenthere;
AC is 240 V Ac.
regards
Then as far as I can see, the triac will definitely blow up. The problem is due to the phase lead of the current through the capacitor.
When the gate drive is removed, the triac will turn off at the next capacitor current zero-crossing. The supply voltage will actually be at or near its peak value, so the capacitor will be charged to near peak supply voltage. During the next half-cycle the capacitor voltage will add to the (opposite sign) next voltage peak, bringing the total to about 678V. The triac you mention is 400V maximum blocking, so it will will break down.
CDRIVE
Joined Jul 1, 2008
2,219
The OP isn't exactly a chatterbox in regards to answering questions. Personally, I think he's a statistic waiting to happen. I also see this thread as more hazardous than most automobile topics that are verboten on AAC.
beenthere
Joined Apr 20, 2004
15,819
I would agree about the danger. The questions have been to try to figure out what this is all about and perhaps save the OP from becoming a statistic.
We'll just close this very shortly unless the OP can say what is it that he is trying to do. A rather complete answer is expected.
Status
