All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-06-2011, 05:39 PM
bassplayer142 bassplayer142 is offline
Member
Default Filtering +-5 Volt power supply
I have a 5 volt power supply that is from a switched mode type supply from futurlec. This unit gives out +-5V, both which need to be further filtered. I need a really clean output with the lowest AC components possible. I have attached a picture of the signal coming out with 20mV divisions and 5usec time divisions.
I tried using simple filter techniques but may have to move up to higher order active filters or something. I'm also considering a zener diode regulator in which I would lose a few volts which is not ideal. Does anyone know of an easy or accurate way to clean this up. Any input is greatly appreciated!
  #2
Old 02-06-2011, 05:48 PM
mik3's Avatar
mik3 mik3 is offline
Default
Use an LC filter on the output.
One side of the inductor on the output, the other on the capacitor. Connect the other side of the capacitor to ground.
Is it one output which outputs either +5V or -5V?
If yes, then take care to use a non polarised capacitor.
If there are two independent outputs, then you will need two LC filters.
The Following User Says Thank You to mik3 For This Useful Post:
bassplayer142 (02-06-2011)
  #3
Old 02-06-2011, 06:36 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Looks like your supply has transients in the 166kHz range to well over 1MHz.
A couple of LC pi filters (one per rail) should take care of that.
1uF cap to ground, 100uH inductor in series, and another 1uF cap to ground will give you a filter that is ~-20dB down by 53kHz, and better than -40dB down by 100kHz. Keep the cap lead lengths as short as possible. Radio Shack sells 100uH ferrite inductors for a couple of bucks; they're axial instead of toroidal so you should really put them in a metal box to keep the radiated noise down.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
The Following User Says Thank You to SgtWookie For This Useful Post:
  #4
Old 02-06-2011, 06:43 PM
Member
Default
Great! I have a few unknown inductors laying around and I'll try them out first. By the way, they are two independent power supplies.
  #5
Old 02-06-2011, 07:39 PM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
Get one each of the small and medium size Goldmine surprise boxes. One of the ones I recently received had a lot of 5 mH per side common mode filters and by the size of the wire (appears to be #20 AWG) they're good for 11A. You could hook them up as series or in parallel. A nice cap on the input and output and you'll be set.
Figures out to be around 5.2K of reactance @ 166kHz yet still able to pass over 10A of current. I would put some small disc or film caps around 0.1 uF or better as well as some good electrolytics both before and after the chokes, 470 uF or better @ 16V should be fine as they'll not only add more filtering but help to reduce any transients should you load change quickly.
You can scavenge these common mode filter chokes from about anything nowadays and they're handy to have around. To hook the two coils in series simply run a diagonal wire between the pins, additive I'm reading 18.85 mH due to the mutual inductance, that would equate to a heck of a lot of filtering and still 10A of allowable current.
They all vary by design thus the reason I tend to suggest getting one of those hand held LC meters off of eBay. Not the same one I have but I'm sure any of these would be quite sufficient:
http://cgi.ebay.com/3-1-2-LCD-Induct...item3a62d8e773
http://cgi.ebay.com/3-1-2-LCD-Induct...item45ecebf1d4
I've checked mine against my B&K bench equipment and they're pretty much spot on as far as accuracy goes.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
The Following User Says Thank You to marshallf3 For This Useful Post:
bassplayer142 (02-14-2011)
  #6
Old 02-14-2011, 03:51 AM
Member
Default
Awesome results with that simple Pi LC filter. Thanks a lot for all your guys help on this. Below is an attached waveform of my (very clean) heartbeat. After I fix up the output a little more and add some calibration stuff I will post this simple ECG schematic in the projects section for a very low cost. My real plan is to make an EEG machine but building the schematic to view a heartbeat is a better indication that everything is working fine before I try to detect brainwaves.
  #7
Old 02-14-2011, 10:39 PM
russ_hensel russ_hensel is offline
Default
Great that you have clean power, but I would ditch it!!! Why? If the power supply fails you could kill someone, low chance, but really bad result. Say switch to batteries and use a couple of regulator chips. Most semi manufactures do not even want you to use their components in these types of devices lest you sue them.
  #8
Old 02-15-2011, 02:44 AM
Member
Default
I have opto-isolators so that I won't have to worry about that!
  #9
Old 02-15-2011, 03:14 PM
Default
Quote:
With just battery power on the human side of the isolators? ( or no power at all )?
Even so are you willing to bet someones life on it? Is 99.99% good enough?
  #10
Old 02-15-2011, 06:55 PM
Member
Default
I understand, and was going to move to batteries anyway. Especially if I'm going to post the stuff on this site. If there is any danger involved it wouldn't be right to post on here and put myself or anyone else in a dangerous position.
Tags
Related Site Pages
Section Title
Video Lecture Inductors (Part 2) - Types and Applications - Inductors,Capacitors,Transformers
Worksheet Design Project: Audio tone control
Worksheet Resonance
Worksheet Inductors
Textbook Resonant filters : Filters
Textbook Resonance in series-parallel circuits : Resonance
Textbook Simple parallel (tank circuit) resonance : Resonance
Video Lecture Inductors (Part 1) - Inductors,Capacitors,Transformers
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Textbook Diode switching circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
24 volt 15 amp power supply jake77 General Electronics Chat 3 02-26-2010 04:48 PM
Help with modification of power supply for LED lighting Bhante The Projects Forum 6 12-18-2009 07:12 PM
Help with HV power supply will1234 General Electronics Chat 0 11-04-2009 10:37 PM
Switching Power Supply cannot power up welcomb The Projects Forum 6 10-20-2009 07:51 PM
7805 & 12VDC Power Supply Problem JDC The Projects Forum 10 10-24-2008 06:09 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
