All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-03-2011, 11:05 AM
xEnOnn xEnOnn is offline
Junior Member
Default Boolean algebra duality principle
My textbook says that the duality principle of the boolean algebra allows me to obtain a same expression in a different form. So for example, X.Y+Z' = (X'+Y').Z
But when I try to plot the truth table, the values of X.Y+Z' is opposite of (X'+Y').Z, which is if one of it is true, the other is false and vice versa. Since this is the case, they are not the same right? Then why are they still considered equal?
  #2
Old 02-03-2011, 03:14 PM
Heavydoody Heavydoody is offline
Default
I am just now doing this at school, so I am no expert. Having said that, my understanding of duality is that for every axiom there is a "dual" axiom created by exchanging and's for or's, or's for and's, 1's for 0's, and 0's for 1's. These dual axioms do not equal each other. So, for example:
x+1=1 has the dual x0=0
(xy)'=x'+y' has the dual (x+y)'=x'y'
However, x+1≠x0 and (xy)'≠x'y'
  #3
Old 02-03-2011, 03:18 PM
narasimhan narasimhan is offline
Member
Default
Absolutely correct.
Actually the dual of X.Y+Z' is (X+Y),Z'
Moreover (X'+Y').Z is the complement of X.Y+Z'
that is ((X'+Y').Z)'=X.Y+Z'
Now draw truth table and verify. And do reply if you get it right and understood the concept.
  #4
Old 02-04-2011, 07:58 AM
Junior Member
Default
hmm.. so the dual axioms are not equal of each other. but I am still a little confused.
So I don't use duality when simplifying expressions since they are not equivalent of each other?
And when given a SOP and asked to convert to a POS, it is just the complement of SOP right? So POS = (SOP)' right?
Funny thing is when I have say X'.Z' + W'.Z as a SOP, and when I "NOT" it to get the POS, I have this: (X'.Z' + W'.Z)' = (X+Z).(W+Z'). But the answer is (X'+Z).(W'+Z')
From X'.Z' + W'.Z to (X'+Z).(W'+Z') looks like duality but isn't the POS and SOP complements of each other rather than dual?thanks.
  #5
Old 02-04-2011, 09:22 AM
Member
Default
Quote:
POS = (SOP)'
That's wrong
Well you got it all messed up. Please read Digital design by Morris Mano. It'll be hard for me to explain the concepts.
First get to know the difference between minterm and maxterm and then POS and SOP.
But anyway here you go
Minterm'=Maxterm
A function F is given in SOP form. to find the POS of F do the following steps.
1. Find the minterms of F
2. Find the SOP of F'(by combining the omitted minterms)
3. Take complement of F' i.e. (F')'=F So you would end up with the POS of F
And remember this
POS of F=(SOP of F')'
  #6
Old 02-04-2011, 03:21 PM
Junior Member
Default
oohhh! The POS is NOT the complement of SOP.
I tried your steps and it works! I got the POS of function F from a simplified SOP of function F.
So the POS is the complement of the omitted minterms, which are the maxterms that return 0 on the truth table. Therefore, I cannot just complement the minterms that I have because by doing so, these are the maxterms that return 1 but not 0, is this right?
Just to clarify something, the minterm are just any m0, m1, m# terms that are not neccessary to need to have result of 1, right? It can also can a result of 0. It is just during the sum of minterms that we gather only the minterms that return 1, right? Similarly for maxterms, the results of the maxterm can either be 0 or 1. But the maxterms must have a result of 0 when I want to put it into a POS.
thanks for your help!
  #7
Old 02-04-2011, 03:35 PM
Member
Default
Till this I understand. You are making quite a progress.
I guess this is also right.
This is a bit confusing.
For sum of minterms you need to include all minterms which are 1.
For product of maxterms you need to include all maxterms which are 0.
Moreover you can't combine minterms and maxterms
  #8
Old 02-04-2011, 08:47 PM
Junior Member
Default
Say if a minterm of A.B'.C' that returns 0. It is not included in the canonical expression of a function F. Does it still being considered as a minterm of the function F even though it does not result in an 1 and is not included in the canonical expression?
So when I complement a minterm that returns 1, it will just be its maxterm that returns 1.
Is listing all the minterms of a simplified expression and the find its omitting minterms and then sum these omitting minterms and then complement them the only way to find the POS? I find myself taking quite long to complete this process.
I see some similarity in SOP to POS with duality. I am not sure if it is just out of coincidence but can it be used as a short cut? Since duality doesn't mean its "dual'ed" form isn't equals to its original form, how is it used in boolean simplification?
  #9
Old 02-05-2011, 05:08 AM
Member
Default
It is not a minterm of F
If you complement a minterm of F it'll become a maxterm of F'(not F).
It is the procedure. Once you master it you can do most of the steps in your mind without pencil and directly arrive at the POS. But it'll require lot of practice.
I'll give an example
You're need to prove the two properties
A) xy+x'z+yz=xy+x'z
B) (x+y)(x'+z)(y+z)=(x+y)(x'+z)
After you prove A you need not prove B. You can just say by duality principle B is also true. i.e B is the dual of A
The Following User Says Thank You to narasimhan For This Useful Post:
xEnOnn (02-06-2011)
  #10
Old 02-06-2011, 02:08 PM
Junior Member
Default
ahh... okay... I get what the duality is for now. It is not for direct expression equivalence. but rather a way to use a rule that was proven for a SOP on a POS or vice versa.
thanks!! thank you so much!!
Tags
Related Site Pages
Section Title
Worksheet Sum-of-Products and Product-of-Sums expressions
Worksheet Boolean algebra
Worksheet Digital display circuits
Worksheet Karnaugh mapping
Video Lecture Completing Truth Tables - Digital
Textbook (sum) and (product) notation : Karnaugh Mapping
Textbook Minterm vs maxterm solution : Karnaugh Mapping
Textbook Converting truth tables into Boolean expressions : Boolean Algebra
Textbook Boolean algebraic identities : Boolean Algebra
Textbook Quantum physics : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Boolean Algebra Identity j3lr0m Homework Help 3 10-15-2010 12:54 AM
Boolean Algebra, equivalent expressions jegues Homework Help 4 09-23-2010 06:55 PM
Help with Boolean algebra bigga Homework Help 3 08-12-2010 12:26 PM
Boolean Algebra captainjapan Homework Help 2 10-22-2008 11:34 PM
Boolean Algebra (Simplification?) kazafz Math 7 08-14-2008 01:53 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
