So I've been spending the past two weeks attempting to design and build an H Bridge for a Power Wheels Jeep. These motors generally draw 15 amps at 12V so the H bridge I need requires a bit more robustness than the general H Bridge designs I've been reading up on.
Basically my issue is that I need some medium on which to layout all of the parts, without having to dish out the money for an expensive PCB board. I have a general perforated PCB, and while the 4 MOSFETs I'm using can be fit and soldered into the board fine, the 12 Gauge wire I'm using cannot. Does anyone have any suggestions as to how I can assemble this H Bridge at relatively low cost? Thanks!
