All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-29-2011, 02:39 AM
fayazahmedmemon fayazahmedmemon is offline
Junior Member
Default How to calculate Dc voltage in full wave center tapped rectifier?
Hi, i am posting the fullwave center tapped rectifier circuit diagram can any one tell me that how can I calculate Dc voltage which is observed by the RL or load? is there any formula to calculate DC voltage in this type of circuit? secondary voltage here is 6 plus 6 rms and each diode is working on the 6v rms in each half cycle.
  #2
Old 01-29-2011, 03:12 AM
K7GUH K7GUH is offline
Default
It looks to me like you have approximately 6 volts d.c. If you add a capacitor across the output, it will rise to 1.414 X 6 = 8.48 volts no load. The voltage will be less when you put a load on the output; best to use a reliable d.c. voltmeter.
  #3
Old 01-29-2011, 07:50 AM
Junior Member
Default
Quote:
Thanks for your kind reply but sir u have only calculate the peak value of the 6v rms.I think there is no relationship b/w capacitor and peak value b/c 6v rms is always equal to 8.48v peak.
  #4
Old 01-29-2011, 01:41 PM
Papabravo's Avatar
Papabravo Papabravo is online now
Default
And you would be wrong. The action of the capacitor is to be charged up to the peak value of the AC waveform, and in the absence of a load to very slowly leak off while the AC input goes to 0 VAC and then rises to the next peak. The actual droop in voltage from one peak of the AC waveform to the next is quite small relative to the AC voltage itself and the short time interval between peaks which is on the order 8.333... milliseconds for a 60 Hz. input or 10 milliseconds for a 50 Hz. input.
It is quite easy to see this ripple on an oscilloscope. You should try it sometime.
__________________
We never have time to do it right,
But we always have time to do it over.
  #5
Old 01-29-2011, 02:56 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
This is probably for a homework problem.
If the theoretical transformer would put out 6v+6v RMS no matter what the load, or if the transformer rating matched the load, the peak voltage across the load would be equal to the RMS value multiplied by 1.414, less the Vf (forward voltage) of the diode at the peak load current.
I don't know what your instructor told you to use for the diode Vf; 0.7v would be likely. Real-world diodes' Vf varies significantly depending on If (forward current), type of diode (silicon, Schottky) maximum If, and Vr (reverse voltage) ratings.
But, using 0.7v for Vf, you would get about 6v X 1.414 - 0.7v = 8.48-0.7v = 7.88v peak.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #6
Old 01-29-2011, 03:10 PM
Papabravo's Avatar
Default
Right -- I should have said:
"charged up to the peak value of the rectified AC waveform"
I was thinking that since I knew that the frequency of the rectified AC waveform is twice the frequency of the mains.
Sorry.
__________________
  #7
Old 01-29-2011, 03:17 PM
bertus's Avatar
bertus bertus is offline
Administrator
Default
Take a look at page 13 and on from this PDF: Unit12.pdf
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #8
Audioguru Audioguru is offline
Banned
Default
The peak current is high in a rectifier that very quickly charges the capacitor. So the rectifier forward voltage drop is close to 1V. It is only 0.4V or 0.5V if the DC load current is small.
  #9
Old 01-29-2011, 04:12 PM
SgtWookie's Avatar
Expert Member
Default
Quote:
If the diode is a 1N4000 series and the load at the peak voltage is 1A, and the diode junction temp is 25C, then the diodes' Vf at 1A would be nominally 1.1v.
A 1N5400 series would have a Vf of around 0.76v with the other parameters being the same.
A 1N5820 Schottky diode would have a Vf of around 0.37v, other parameters being the same.
I'm not being argumentative here; just trying to illustrate that our original poster will need to use the Vf @ current specification that their instructor told them to use; if a particular model/series/part# diode was specified, they will need to find the datasheet for it.
__________________
General info:
  #10
Old 01-29-2011, 09:02 PM
soda soda is offline
Location: Worcester(Western Cape),South Africa(GMT+02:00)
Default
@Wookie,
An friend gave me this to keep for a reference. Please look at it and tell me if it's ok to use
Tags
Related Site Pages
Section Title
Worksheet Performance-based assessments for semiconductor circuit competencies
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Worksheet Advanced electromagnetism and electromagnetic induction
Worksheet Peak, average, and RMS measurements
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Full-wave bridge rectifier : Discrete Semiconductor Circuits
Textbook Full-wave center-tap rectifier : Discrete Semiconductor Circuits
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to convert High voltage Dc to AC? fabieville General Electronics Chat 22 09-15-2010 12:29 AM
How I can determine ripple voltage in full wave rectifier circuit ? Radoi General Electronics Chat 11 06-06-2010 05:52 PM
Why use full wave rectifier with DC? Sigh The Projects Forum 6 03-05-2009 12:01 AM
A Full wave precision rectifier query trytolearn General Electronics Chat 14 02-12-2009 04:51 PM
i need a simple full wave rectifier application with circuits raghavan General Electronics Chat 1 07-11-2008 04:17 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
