All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-24-2011, 04:37 PM
alexilla alexilla is offline
Default Variable Voltage Controller
I need some suggestions on creating a power supply that is capable of varying voltage from near zero to 120vac at about 3A and is capable of accepting a milliamp signal from a controller IC. I need a very quick response time for partial load to full load voltage. This is for varying the voltage on an electrical resistance heater coil that has to maintain a set airflow temperature through a tube. As the airflow varies from none to high flow, the coil voltage has to continuously adjust to maintain the temperature set point and to avoid damaging the coil when the airflow is minimal. ie... low airflow, low coil voltage; high airflow, high coil voltage. Any help would be greatly appreciated. Thank you.
Alex
  #2
Old 01-24-2011, 05:27 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The resistance heater will operate on DC as well as AC, and with DC you can use a form of PWM to control the heat. Otherwise, you can use a TRIAC to control current.
That milliamp level signal will almost certainly need amplification. Can you post the schematic?
__________________
First comes the hardware, then the software.
  #3
Old 01-24-2011, 06:58 PM
wayneh wayneh is offline
Default
Quote:
Originally Posted by alexilla View Post
...accepting a milliamp signal ...
That's a unit of measure, not an amount. Do you mean in the hundreds of mA (probably usable without amplification), or single digits (needs amplification)?
I agree that PWM control of a MOSFET "switch" would be a good option here to control a DC heater, with the PWM being controlled by the controller voltage.
The old-school approach is a variac under thermostatic control.
Tags
Related Site Pages
Section Title
Worksheet Calculus for electric circuits
Worksheet Microcontroller principles
Worksheet Regulated power sources
Worksheet Zener diodes
Textbook Synchronous Motors : Ac Motors
Worksheet Inductance
Textbook Winding configurations : Transformers
Textbook Special transformers and applications : Transformers
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Please help me with High Low voltage cutoff with time delay sakbd.2010 The Projects Forum 61 11-26-2010 11:32 AM
Back-Emf vs. Voltage shespuzzling Physics 18 01-13-2010 09:29 PM
Help with MOSFET variable voltage circuit? Mike33 General Electronics Chat 9 12-29-2009 11:24 AM
dc variable voltage reduction chrisvanbekkum General Electronics Chat 4 04-07-2009 05:11 PM
Need a Circuit to use PWM to generate variable Voltage output El3ctroded The Projects Forum 10 04-22-2008 03:53 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
