All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-18-2011, 12:44 PM
hokage hokage is offline
Default Project Help!! Wind monitoring system.
Hi, I am given a project titled" Wind Monitoring System". Can someone give me some information on how to do the hardware and software of the project? What software to use? Thanks~
  #2
Old 01-18-2011, 01:05 PM
beenthere's Avatar
beenthere beenthere is offline
Default
You could make a start with getting information on "anemometers". Until you state the parameters of the monitoring system, it is impossible to say if your choices are correct.
Software is specific to the microprocessor/computer to be used. What background do you have?
This sounds like an assignment, so I will move it to a better section.
__________________
First comes the hardware, then the software.
  #3
Old 01-18-2011, 01:16 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
If you want to make an anemometer without moving parts, then look for a thermal anemometer.
This site will give you a lot of info how to make one:
http://www.fonema.se/anemom/anemom.html
Bertus
PS I edited the title of the thread so the people know what the project is about.
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #4
Old 01-19-2011, 06:14 AM
Default
Thanks for helping~ The parameter is speed, temperature and direction. How to build the PIC 18F 4550 circuit? What is the components needed? How to read the data to computer? Sorry that im very noob on this things~
  #5
Old 01-19-2011, 12:23 PM
beenthere's Avatar
Default
What resources do you have? Things like tools and test equipment.
Do you have the means to make printed circuit boards? Have you any background in programming?
__________________
  #6
Old 01-19-2011, 02:29 PM
t06afre's Avatar
t06afre t06afre is offline
Default
I do not think your teacher just out of the blue just slapped a PIC 18F4550 in your lap. And told you to use it. I am sure you have one or more MCU classes as a preparation for this project. And that all you need of equipment are located at your school. You are just somewhat apprehensive about this project because this is your first real world project. And you can not just open a textbook and read until you find an answer. You have to navigate in unknown water.
You have already gotten some tips about the wind sensor. For the wind direction I would have Googled Rotary encoder. I think in this case a 8 positions Rotary encoder will do. But that you have to discuss with your teacher.
For communication with a PC. Using RS232 will be the simplest way of doing the communication with the PC. You can use USB. But that will require much more programming and knowhow from your side. It is important that you keep things simple. Do not add nice nice to have details before you have all the need to have details working. You can of course ask for help in this forum any time. But your teacher is also an important source of information. The trick is to always be prepared then asking questions. Before asking any questions you must be able to explain what you have done. And why and how struggle. And the same will go for asking questions in this forum. Then you ask questions Always post your code or schematic. It is very hard to give you any help without that kind of documentation.
  #7
Old 03-15-2011, 01:31 AM
Default
Can anyone tell me how to build wireless wind monitoring system?
  #8
Old 03-15-2011, 01:41 AM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
NO, we cannot provide a simple, easy to follow, set of instructions for building YOUR project.
we CAN help you with problems you have in the construction of YOUR project. All you need to do is show the work you have completed and where the problem is located within that work. We will then try to guide you along a different path toward a solution.
WE WILL NOT DO YOUR HOMEWORK FOR YOU.
__________________
I'm too old.
  #9
Old 03-15-2011, 02:02 AM
Kermit2's Avatar
Default
http://www.seekic.com/forum/22_circu...NEMOMETER.html
Start simple and get something like this put together. Then when it is working you can increase the circuit by adding an analog to digital converter to it. then you add the display decoding, then you can add more monitoring devices for temp and direction.
__________________
I'm too old.
  #10
Old 03-20-2011, 03:42 AM
Default
Hi, I'm using Visual C++ to do the GUI but i got this error after i build it:
1>------ Build started: Project: wms 2, Configuration: Debug Win32 ------
1>Compiling...
1>stdafx.cpp
1>Compiling...
1>AssemblyInfo.cpp
1>wms 2.cpp
1>c:\users\amy\documents\visual studio 2008\projects\wms 2\wms 2\Form1.h(6) : fatal error C1083: Cannot open include file: 'Startup.h': No such file or directory
1>Generating Code...
1>Build log was saved at "file://c:\Users\Amy\Documents\Visual Studio 2008\Projects\wms 2\wms 2\Debug\BuildLog.htm"
1>wms 2 - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
I attached the file with the code. Hope anyone can help me~ Thanks!!
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet AC motor control circuits
Worksheet Impedance matching with transformers
Worksheet Autotransformers
Worksheet Step-up, step-down, and isolation transformers
Worksheet Mutual inductance
Worksheet DC generator theory
Textbook Three-phase Y and Delta configurations : Polyphase Ac Circuits
Textbook Step-up and step-down transformers : Transformers
Textbook Winding configurations : Transformers
Similar Threads
Thread Thread Starter Forum Replies Last Post
How to post a project to the collection Dave The Completed Projects Collection 1 01-30-2013 08:15 PM
Science project: Suggestions for timer and pull solenoids EvaM The Projects Forum 5 12-13-2010 07:31 AM
Project: Temperature and Humidity Data Logger Project OldSpring The Completed Projects Collection 2 06-12-2009 07:29 PM
Help wanted with Humanitarian electronics project Humanise The Projects Forum 0 03-17-2009 01:19 PM
What is a Project? jpanhalt Feedback and Suggestions 8 02-09-2009 02:17 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
