All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-17-2011, 12:14 AM
nDever nDever is offline
Member
Default Parallax Propeller 32K EEPROM Substitute
Hey Guys,
I am preparing to use a Parallax Propeller Microcontroller. The MCU's program can either be inputted into the chip directly via USB or read into the chip by way of external 32K Serial EEPROM. I would like to use the external memory option, however, I would like to be able to substitute the EEPROM if I can with a 28C256 Paged EEPROM because it is readily available. I would have to make a few modifications to the circuit because the MCU communicates to external memory serially (Address/Data I/O, Clock). Can you guys offer me any options available to connect a serial MCU with a parallel memory chip?
I believe that I can communicate with memory if I connect its data output pins to a PISO shift register and connect the register's clock to the MCU's clock and have the data shifted out of the register every pulse.
  #2
Old 01-17-2011, 12:19 AM
blueroomelectronics's Avatar
blueroomelectronics blueroomelectronics is offline
Default
Even the most simple circuit would cost more than a commonly available 256kb serial EEPROM. What part of the world can get a Parallax Propeller but not a 24LC256?
__________________
Bill
  #3
Old 01-17-2011, 12:35 AM
Member
Default
The schematic calls for 256K but Jameco does not have the 24LC256 at the moment. Will I be able to use a 24C512? I assume this means that the circuit will still work but I will have more space than necessary?
  #4
Old 01-17-2011, 12:37 AM
Default
The 512 might work, try the Parallax forums for an accurate answer.
__________________
Bill
Tags
Related Site Pages
Section Title
Worksheet Memory devices
Textbook Historical, nonmechanical memory technologies : Digital Storage (memory)
Textbook Serial-in, parallel-out shift register : Shift Registers
Textbook Serial-in/serial-out shift register : Shift Registers
Textbook Introduction : Shift Registers
Similar Threads
Thread Thread Starter Forum Replies Last Post
EEPROM Programmer using PIC PRS Embedded Systems and Microcontrollers 6 11-18-2010 11:54 PM
PIC EEPROM programmer - almost working, not quite Tekk Embedded Systems and Microcontrollers 3 12-21-2009 04:38 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
