All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-08-2011, 02:46 AM
Nano001 Nano001 is offline
Member
Default 2 MOSFETs in series
Hi I have a simple question. Why is it that 2 MOSFETs in series are used as a current source instead of 1? For example in a differential amplifier, or in a cascode current mirror. What is the advantage of using 2 over just a single one? Thank you.
  #2
Old 01-08-2011, 03:52 AM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
Please provide an example circuit, contrary to popular belief we can't read minds nor guestimate unless we know what we're looking at.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
  #3
Old 01-08-2011, 05:31 PM
gizmoman0 gizmoman0 is offline
Junior Member
Default
This page explains a few advantages of a cascode setup
http://en.wikipedia.org/wiki/Cascode
  #4
Old 01-08-2011, 06:35 PM
retched's Avatar
retched retched is offline
Default
Quote:
I dunno.... we are better at mind reading then most sites...
It is just EXHAUSTING!
__________________
-rm-
  #5
Old 01-08-2011, 06:42 PM
Junior Member
Default
i think hes talking about one of these typical circuits
http://en.wikipedia.org/wiki/File:Long-tailed-pair.gif
  #6
Old 01-08-2011, 07:54 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
Quote:
One transistor is set up for properties such as high input impedance, but little gain, while the second is set up for high gain and lower output impedance.
In a current mirror, one transistor is biased to always carry a certain current, which biases the second transistor properly to process outside signals.
Check out This Section of the e-book that explains the properties of common emitter, common base, and common collector circuits. The MOSFET equivalents have similar properties and reasons for use.
  #7
Old 01-08-2011, 08:17 PM
marshallf3's Avatar
Default
I'll agree, there are a lot of people here that go far out of their way to help on a valid question. Some of them stump even the best, others are so simple I don't even bother responding as I'm hoping some of the younger, less experienced people will take it to their heart to try and research the answers as they often end up learning something that way too.
Of course I've got a lot of holes in my education so, as with anyone, I may not have a clue. I occasionally give the wrong answer as well but everyone's rather quick at correcting my mistakes so I learn from that.
__________________
  #8
Old 01-09-2011, 10:14 PM
Member
Default
I ttached 2 pictures of what I am talking about. The first is a differential amplifier. I am curious why 2 MOSFETs are needed instead of 1 (the 20/2 FETs) and what the effect of 2 separate biasing voltages for them are.
Also, I attached a picture of a cascode current mirror. I understand what a current mirror does, however I don't understand the advantage of the cascode, and how the current flows through the right two MOSFETs in series. Iref flows through the left 2 MOSFETs, and if the transistors sizes match, Io=Iref. What is the advatange of cascode, I saw the link gizmomano posted, however it is still a bit unclear. I just need a simple explanation to clarify. Thanks very much.
  #9
Old 01-10-2011, 01:03 AM
marshallf3's Avatar
Default
Back up and go through the theory of how Op Amps were originally designed, it may help to shed a bit of light.
__________________
  #10
Old 01-17-2011, 06:11 PM
Member
Default
Ok, I was reading and I found out that the cascode current mirror is used to increase the output resistance so the current becomes relatively independent of the output load. However, I still don't understand the application of the diff amplifier that I posted, and what the biasing on the separate MOSFETs does.
Tags
Related Site Pages
Section Title
Textbook The cascode amplifier : Bipolar Junction Transistors
Similar Threads
Thread Thread Starter Forum Replies Last Post
Parallel MOSFETs keyturbocars The Projects Forum 37 12-16-2010 02:55 PM
Is a wire dipole a series circuit or not? KL7AJ General Electronics Chat 5 07-22-2009 10:51 AM
Fourier series coefficients whoozit Homework Help 2 02-29-2008 09:17 AM
C program for sine series circuit2000 Programmer's Corner 4 04-28-2007 10:02 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
