I working on a little electronics project and I've hit a little problem. There will be a square wave being generated with about a 50% duty cycle. What I need is something that will go High when the square wave goes high, but then go low before the High part of the wave ends. The ratio of square wave high to the circuits High doesn't matter that much, just that it's high long enough to allow a relay to switch but not so long that it's high most the time the square wave is high.
I first thought about using a astable 555 timer but realized that it would stay high the whole time it's input is high.
I don't have a whole lot of room left on my breadboard, and I'd really like to not have to buy another, so the simpler the better. I've tried a few things with capacitors but I can't get them to work.
Any Ideas appreciated.
Also, the picture is basically what I want to do.
