Hi, i need help detecting a low battery situation. I want to power a small system with a 9V battery but using a 5V regulator. However I want to know how can I detect the battery low condition using a micro controller, so that when it is detected I can turn on a LED to let the user know he should change the battery.
I found out that some PICs come with a HLVD, but I am not sure if I must include a constant power supply that wont degrade to compare it with, or if everything is done internally and I don't have to include anything else.
In case I were to use a PIC without HLVD, how would you recommend doing it?
