All About Circuits Forum
Go Back   All About Circuits Forum > Software, Microcomputing, and Communications Forums > Radio and Communications
Notices
Radio and Communications Discussion forum for all aspects of RF and communication engineering, including antennas, modulation regimes, RF circuits and filter design, and telematics.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-16-2010, 04:44 PM
steveparrott steveparrott is offline
Junior Member
Default RFI with LED lighting
I'm a lighting manufacturer and have started to hear complaints about outdoor LED lights interfering with garage door openers (GDO's). It's a known problem that many electronic circuits can interfere with these RF transmitters/receivers.
After talking with Chamberland, a major mfg. of GDO's, they tell me that RFI can come from other RF devices that transmit at certain frequencies; and it can come from devices that somehow transfer interference over electrical wiring. GDO's typically transmit at 315 MHz.
LED engineers tell me that a properly designed LED circuit will limit or filter unintended RFI. They also say that they wouldn't be surprised if many of the cheap China exports fail to control RFI.
A few questions:
1. Would it be possible that a 12V AC LED circuit could somehow transfer interfering frequencies through it's lead wire, through a torroidal transformer, through the house wiring to the garage door receiver?
2. If that's possible, what could an electrician put in place to block this transmission?
3. Regarding the interfering frequencies, Chamberland tells me that other devices that transmit at the same frequency (315 MHz) can definitely interfere, but other frequencies may also interfere. Can someone explain how this is possible?
4. I understand that RF emissions can be measured with certain equipment. Does the same equipment also measure the sort of frequencies that travel over wires? Are the two types of transmission (air and wires) basically the same?
Thanks for your help.
  #2
Old 12-16-2010, 05:51 PM
Audioguru Audioguru is offline
Banned
Default
Maybe garage door receivers are an extremely simple super-regen circuit that is easily overloaded and picks up all kinds of interference?
Maybe they use simple AM which picks up amplitude interference instead of FM?
  #3
Old 12-16-2010, 08:32 PM
Kermit2 Kermit2 is offline
Default
Backward coupling through the power transformer into the house wiring and AGAIN through another power transformer into the GDO circuit is extremely unlikely. 60Hz power transformer will cause ungodly db loss in a 315MHz signal. The interference will not be getting in that way.
The metal structure of the GDO and the tracks for the door are all metal and some doors are metal as well. Seems the logical entry method for a radio freq signal. Some piece that is a near perfect wavelength or multiple thereof acting like an antenna for the LED circuits operating freq.
__________________
I'm too old.
  #4
Old 12-16-2010, 08:35 PM
Default
If you set up any testing situations to achieve the interference condition, you could try simple solutions (cheap) to see if they help, or even cure it.
Isolating the LED circuit with a transformer to remove its reference to the household ground circuit, or conversely, isolating the GDO circuit power from ground the same way to break its tie with any grounded structures. Would be cheap to implement and to test for effect.
__________________
I'm too old.
  #5
Old 12-16-2010, 09:04 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
What are your outdoor LED lights?
How much power, what type of power supply, etc? Are there long wires inside that are regulated with a switch mode power supply? You can try adding a few bypass capacitors across long wires carrying power to reduce their chance of acting like an antenna.
Would need more information about the LED circuit, power supply and drive for ideas of what could be causing the issues.
How far away from the garage door opener are the LED lights that are causing the interference?
  #6
Old 12-16-2010, 09:15 PM
Default
Other freq. can interfere if they are multiples of the base freq of interest.
So 630MHz 1.26GHz 2.52GHz
Or 157.5MHz 78.75MHz 39.375MHz could all be freq that interfere. Even signals that are merely close to the equipment and not even freq related can interfere due only to close proximity. Remember that annoying noise radios TV's and computers make when your cell phone is right next to them and rings?
__________________
I'm too old.
  #7
Old 12-16-2010, 09:30 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
Do you have more details on the leds reciever?
RFI has mainly to do with bad shielding or bad filtering.
See these pages from the EDYCYPEDIA for more info:
http://www.educypedia.be/electronics/emc-emi.htm
http://www.educypedia.be/electronics/componentspas.htm
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #8
Old 12-16-2010, 11:41 PM
beenthere's Avatar
beenthere beenthere is offline
Default
LED's as a potential source of RFI seems unlikely. They operate on/off if twinkly, and do not use PWM schemes for dimming.
__________________
First comes the hardware, then the software.
  #9
Old 12-17-2010, 12:00 AM
Default
The most likely source of a multi hundred mega Hertz RF noise is a poorly filtered switching power supply in the LED device. The LED's themselves wouldn't radiate any RF, but a power supply can do so easily.
__________________
I'm too old.
  #10
Old 12-20-2010, 05:32 PM
Junior Member
Default
Thanks for the replies.
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet Fundamentals of radio communication
Textbook Radio circuits -- INCOMPLETE : Practical Analog Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
Arduino code Noob Need help Turkish The Projects Forum 7 09-03-2010 05:36 AM
Pls help me.Need advice ridge84 Embedded Systems and Microcontrollers 4 11-29-2009 09:35 PM
LED office-desk lighting system kdaffolder The Projects Forum 1 08-04-2009 07:43 AM
LED Lighting. I need some design and theory help. Tom Kay The Projects Forum 19 03-04-2009 03:19 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
