All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Electronics Resources
Notices
Electronics Resources Get help with all types of electronics resources, including books, websites, datasheets, technical literature, and software.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 02-07-2007, 01:22 PM
Rouen Rouen is offline
Default Plasma and LCD TV info and training
Hi
I've repaired TV's for the last fifteen years.
Now that plasma and LCD TV's are becoming so popular I need to find out how to repair them.
Are there any websites, books,ebooks or training manuals avaliable?
Rouen
  #2
Old 02-08-2007, 05:42 AM
mrmeval mrmeval is offline
Default
Sams Photofact is no more and thier former service to the repair community would be illegal now. So you're stuck getting schematics from the manufacturer if they will provide them.
Your best bet would be to attend factory training offered by all the manufactuers.
You have to become an authorized servicer and there may or may not be an annual fee but the training is something most manufacturers provide to authorized servicers at no charge and it's even required that an employee attend. 1
I've repaired countless monitors and LCD systems when analog was king. The newer digital stuff would require more expensive test equipment as the data is in many cases a high speed serial stream that's eventually decoded to control the pixels in the LCD.
Plasma is similar though the final output to the display is different.
  #3
Old 02-09-2007, 01:28 PM
Dave Dave is offline
Default
In the new digital world, sadly things are not designed to be repaired, but replaced. This very fact may inhibit your ability to find any suitable information. If you do find anything it would be interesting to see what is available.
Dave
  #4
Old 02-09-2007, 07:37 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
Quote:
Originally Posted by Rouen View Post
Hi
Rouen
Nowadays it is the rule rather than the exception that...
"there are NO serviceable parts inside"
  #5
Old 02-16-2007, 08:37 AM
Default
Thanks for the input guys, on a different tack then what about a source of cheep replacement boards for various makes of plasmas and LCD's?
As I am in South Africa price is everthing(exchange rate)
  #6
Old 02-16-2007, 12:19 PM
Papabravo's Avatar
Default
I am by no means convinced that the manufacturers have any interest whatsoever in making spare parts available. They really don't want people opening the things up and messing around inside. So if they are available at all they are priced the same as a whole new unit. As you can imagine this effectively eliminates any economic incentive to repair a unit. Also since everything is done with software even if you could replace a board how would you upgrade the firmware?
  #7
Old 02-19-2007, 04:52 AM
RAH1379 RAH1379 is offline
Member
Default
do a search for books by robert goodman, he has a new book out on the subject, ive seen it in the bookstore catalog from cleveland institute of electronics bookstore.
  #8
Old 02-28-2007, 11:46 AM
goodbyegti goodbyegti is offline
Member
Default
I found that quite often modern electronics like projectors, LCDs etc.. all have built in switch mode PSUs. When these go wrong they seem to be quite easy to understand and fix.
There is a great site here:
http://www.repairfaq.org/sam/smpsfaq.htm
Having said that one of the most common faults i see with LCDs is a failed inverter. I've only ever looked at a few, one of which was from an old monitor, it turned out a simple component had gone out of spec. However i've seen a lot of failed Fujitsu inverters where the transformer has broken - these are usually proprietary and near impossible to obtain. Same goes for Dell laptop inverters, i've seen a couple with shattered ferrites.
  #9
Old 02-16-2008, 07:35 AM
Guilngan Guilngan is offline
Default
Try this website,there is an e-book on LCD monitor repair by jestine yong
www.electronicrepairguide.com/
  #10
Old 02-19-2008, 04:22 AM
thingmaker3's Avatar
thingmaker3 thingmaker3 is offline
Super Moderator
Default
Quote:
This is true. The downside of this mentality is the death rattle we hear in the lungs of our economy. The upside is that anyone clever enough to repair the junk has easy access to high-end toys at near zero cost.
__________________
"I want to establish in your mind very clearly that you must not think I deny all that I do not admit. On the contrary, I think there are many things which may be true, and which I shall receive as such hereafter, though I do not as yet receive them; but that is not because there is any proof to the contrary, but that the proof in the affirmative is not yet sufficient for me"
- Michael Faraday
Tags
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
