All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-13-2010, 02:16 PM
ssembo ssembo is offline
Junior Member
Default Automatic load sharing of a transformer system with protective analysis
Hello friends,
i am working on a project stated in subject. In this project, a slave transformer is supposed to share the load of a master transformer over load and over temperature. A sensor circuit must be designed to log data from the master transformer and if it is found to be in the over load condition immmediately the slave transformer will be connected in parallel to the master and the load will be shared.
I read some where that an operational amplifier can be used to compare the load of the transformer with a standard load capacity and an NPN transistor can be used to drive a relay. That the project uses a regulated 5V, 750mA power supply, a three terminal voltage regulator for regulation and a bridge type full wave rectifier is used to rectify the ac output of secondary 240/12V step down transformer.
i would like also to add on the issue of the slave transformer coming in and disconnecting the master when a fault occurs on the master transformer.
Any one able to provide me with the neccessary infomation and the required circuit will highly be appreciated.
Thanks.
Ssembo.
  #2
Old 12-14-2010, 04:13 AM
timrobbins's Avatar
timrobbins timrobbins is offline
Default
Ssembo, which part of the design did you want to do yourself ;-)
Ciao, Tim
  #3
Old 12-16-2010, 12:26 AM
Junior Member
Default comparator
Quote:
Ciao, Tim
i can make the part that compares the load, power suply needed and rectification. am wondering how i can incooperate the relay and also the switching incase of fault.
Thank you man for responding.
Tags
Related Site Pages
Section Title
Worksheet Protective relay circuits
Worksheet Flip-flop circuits
Worksheet Thyristor application circuits
Worksheet Power conversion circuits
Worksheet Insulated gate field-effect transistors
Worksheet Bipolar junction transistors as switches
Worksheet Basic AC-DC power supplies
Worksheet AC motor control circuits
Worksheet Step-up, step-down, and isolation transformers
Textbook Protective relays : Electromechanical Relays
Similar Threads
Thread Thread Starter Forum Replies Last Post
circuit for automatic transformer distribution and load sharing system narayana General Electronics Chat 2 09-20-2009 09:40 PM
Full-Wave Bridge Rectifier Filter + Regulator DC Power supply Petrucciowns Homework Help 52 07-10-2009 05:30 PM
About Load Analysis sharath_412 General Electronics Chat 2 10-22-2007 10:06 AM
BJT : AC Load Line Analysis Tarquin Homework Help 5 12-23-2006 08:57 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
