| The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it. |
Thread Tools | Display Modes |
#21
To know your battery intimately:
http://www.cadex.com/prod_analyzers/7000_overview.asp Commercial level battery analyzer, far more than what any "easy" circuit can do. You may also find a system like the Triton Charger/Analyzer which does load testing with high current, capacity measurement, charging, and cycling for Nickel based batteries, supports every type from Lithium to lead acid though. If you disassemble the pack, you can verify all cells are taking an equal charge, and show very close to the same voltage when the pack is under a 2 Amp load (8 Ohm power resistor, etc).
__________________
Bypass Caps! Read Me Also-Impedance Graph paper. |
#22
This may be of use/interest to you: http://www.eevblog.com/2010/08/01/ee...ttery-testing/
| Tags |
| battery, cordless, power, tester, tool |
Related Site Pages
| Section | Title | |||
| Worksheet | Time constant calculations | |||
| Worksheet | Time constant circuits | |||
| Worksheet | Kirchhoff's Laws | |||
| Worksheet | Batteries | |||
| Textbook | Battery ratings : Batteries And Power Systems | |||
| Textbook | Electron activity in chemical reactions : Batteries And Power Systems | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| motor bicycle magneto and battery | dougan778 | The Projects Forum | 1 | 07-22-2010 09:11 PM |
| How does this Intelligent Battery Tester work? | ngaiseng | The Projects Forum | 1 | 07-20-2010 07:38 PM |
| Ways of Driving a High Power Stepper Motor at 24V, from a 12V Battery. | sweaterlife | The Projects Forum | 1 | 03-24-2010 11:22 PM |
| Calculating and displaying power consumption of a load through battery | ammarqs | The Projects Forum | 2 | 03-12-2010 07:22 PM |
| All-Sun BT21 Battery Tester - Voltage Reading Problem | D1G1T4L3CH0 | General Electronics Chat | 0 | 01-21-2010 01:53 AM |
| Thread Tools | |
| Display Modes | |
