All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 12-05-2010, 05:42 AM
HaPPy_BoY HaPPy_BoY is offline
Junior Member
Default Mosfet IRF540 latch-up
Hi guys. I'm doing some project which will use mosfet as a switch. So, i tried to play with some mosfet first; the irf540. I tried out the simple circuit like turning led on/off found in the internet. I have a crystal oscillator connected to a comparator to provide signal to the gate and i use supply voltage of 12V from sla batt to the drain.
When i powered up the led turned on, but when i removed the signal from the gate, the led kept turned on. Then when i removed the supply voltage and reconnect it back the led did not turned on without signal from gate. So what is the problem ? Is the mosfet spoilt ?
I tried to find any statement on this on the net but i'm very confused as I'm new to building practical circuit other than simulation.
  #2
Old 12-05-2010, 06:28 AM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
Do you have a schematic of the circuit you assembled (attach as a .PNG file)
Can you provide a photo of the circuit you assembled (attach as a .JPG file)
  #3
Old 12-05-2010, 06:55 AM
S_lannan's Avatar
S_lannan S_lannan is offline
Send a message via MSN to S_lannan
Default
Power mosfet gates have substantial capacitance and need to be driven low to turn off. Just removing a signal will not discharge the gate.
  #4
Old 12-05-2010, 07:52 AM
Junior Member
Default
The circuit is attached (tran21.gif & 05122010398.jpg) .. I hooked the output of the oscillator to non-inverting input and ground the inverting input of the comparator lm358N. The output of the comparator is to the gate of the mosfet.
Also, i wonder if mosfet is suitable to be used in dc-dc luo converter. I'm building one voltage regulator to drive servo controller with 10 servo motors attached.
  #5
Old 12-05-2010, 10:49 AM
Junior Member
Default
I like to know more about the gate voltage of the mosfet irf540. I read from net that it is required that the gate voltage to be referenced to the drain voltage in order to fully turn on the mosfet. Is this true for irf540 also ? Let's say the next time i supply 12V to the drain then would I need Vgs=12+4 V ?
  #6
Old 12-05-2010, 02:11 PM
beenthere's Avatar
beenthere beenthere is offline
Default
That is not correct. The gate voltage is relative to the source voltage. Full conduction comes when the gate is at least 10 volts positive with respect to the source.
__________________
First comes the hardware, then the software.
  #7
Old 12-05-2010, 02:22 PM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
In the case of a p-channel enhancement type mosfet then the gate voltage will need to be taken negative with respect to the source.
hgmjr
  #8
Old 12-05-2010, 02:40 PM
wayneh wayneh is offline
Default
Quote:
Originally Posted by HaPPy_BoY View Post
...when i removed the signal from the gate, the led kept turned on.
With the circuit you posted (which should work)? What is the value of the resistor connecting the gate to ground? As noted, the gate is a capacitor and the charge must be drained off for the state to change.
FWIW, I have a handful of that exact same MOSFET and it's what I use whenever I need one. No particular reason, I just had to pick one and that was it.
  #9
Old 12-05-2010, 02:50 PM
beenthere's Avatar
Default
Quite true, but the IRF540 is N channel. The gate would have to go negative if it were an IRF9540.
__________________
  #10
Old 12-05-2010, 02:58 PM
hgmjr's Avatar
Super Moderator
Default
Quote:
Yeah. I was aware that the target device was an n-channel. I was just elaborating on your comment about the n-channel for the sake of completeness.
hgmjr
__________________
"No human being should be allowed to have this much fun."
hgmjr
May we never lose compassion for those who need our help and encouragement.
Tags
Related Site Pages
Section Title
Worksheet Flip-flop circuits
Worksheet Latch circuits
Worksheet CMOS logic gates
Worksheet Insulated gate field-effect transistors
Textbook Modern nonmechanical memory : Digital Storage (memory)
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Video Lecture MOSFET Amplifiers - Transistors and Transistor Circuits
Textbook Synchronous counters : Sequential Circuits Counters
Textbook NAND gate S-R flip-flop : Digital Integrated Circuits
Textbook NOR gate S-R latch : Digital Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Building a set-dominant gated SR latch jegues Homework Help 2 10-22-2010 08:41 PM
DC DC boost converter design S_adnan General Electronics Chat 16 07-29-2010 08:30 PM
9530 MOSFET vs a 9014 MOSFET Glitchmobile General Electronics Chat 3 05-14-2010 04:25 AM
Use MOSFET to perform circuit ON/OFF winson General Electronics Chat 4 03-18-2009 01:57 PM
IRF540 mosfet thermal runaway? hobbyist General Electronics Chat 7 08-29-2008 10:59 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
