hi all, i need help with this
prove or disprove :
if F:R -> [a,b] is contractive on [a,b] then F has a unique fixed point,
which can be obtained by function iteration staring an any real value.
That might be true, given that you need g'(x)<1, x in [a,b] in order for the function to be contractive. Since all the potential fixed points lie on the line f(x)=x which has f'=1, our function g can intercept f only once.
Intercepting it twice would mean that in some interval its derivative would be >1 and that is unacceptable, since g is contractive in the whole space [a,b] not in some subspaces.
So a contractive mapping is one in which the points in the domain are brought closer together in the range. In differential equations a fixed point is one where the velocity goes to zero.
On Wikipedia there is a development of the Banach Fixed Point Theorem that you might find useful. I'm close to being able to follow it.
