All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-30-2007, 08:12 AM
arvin arvin is offline
Default How can I float the low side gate of a half bridge?
I'm trying to have an N- channel mosfet half bridge work between negative and positive voltages (say -50v and +50V).
If I am not wrong I need around -40 V to trigger the low side mosfet ( for
Vgs = 10)
However when I check the IC s the only side mentioned to be floating
is the high side.
I was able to float the low side using a gate transformer but I wonder if there
is a discrete method to do it using IC s ( ex ir2113 etc)
thanks
  #2
Old 01-30-2007, 03:54 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The accepted standard is to run the lower leg grounded and all the voltage on the upper. Is there any reason you can't reconfigure your source voltage to run between 0 & 100 volts?
  #3
Old 01-30-2007, 08:29 PM
dragan733 dragan733 is offline
Default
Vgs = 10)
is the high side.
thanks
You can drive directly the low side with a zener diode between GS, for example 12V. Anode of the zener to the G. Or send your schematic with purpose to be clear.
  #4
Old 01-31-2007, 11:19 AM
Default I use rectified ac
Quote:
Originally Posted by beenthere View Post
First of all thank you for the messages !
I hope I don't have fundamental flaws
I use a mono phase ac supply which gives + and - when rectified.
............----->|------|---------- ..+volts--\
...........|..................= ...........................mosfet
ac~----|..................|------- 0v................load
...........|..................=................... ........mosfet
............-----|<------|---------- ..-volts--/
I'd like to use the whole voltage range,how can I drive the lower mosfets ?
thank you
  #5
Old 01-31-2007, 01:34 PM
beenthere's Avatar
Default
If that's a transformer and bridge rectifier, all you have to do is use the negative output as the ground reference. The transformer isolation makes this possible. In effect, you will have a +100 VDC source. Just leave the transformer's center tap lead disconnected. Then you can hook up your half bridge in the "conventional" fashion.
Kind of makes you wonder why Mr. Edison fought so hard against AC power?
  #6
Old 02-01-2007, 03:36 PM
Default
Hi again,
I am still confused.
If you could please check out the figure 1 on page
http://www.elektrorevue.cz/clanky/2004/0014/
you'll see the positive and negative rails of 270 / -270 volts.
There it says use galvanic isolation and shift the gate drivers ground to
-270v.
I am not so sure how I'm going to apply it to a gate driver ic like ir2113
Vss and com, are they going to have the low rail voltage and Vdd is it going to be the low rail +15 volts ?
I hope the question is clearer
thanks
  #7
Old 02-01-2007, 06:25 PM
beenthere's Avatar
Default
Is this a school assignment? If so, I'll move it to the homework help section where it will get better exposure.
  #8
Old 02-01-2007, 07:13 PM
Default
sure ..
thanks
  #9
Old 02-02-2007, 05:41 PM
beenthere's Avatar
Default
That is an odd circuit, in that a bridge driver normally changes the path of the current rather than the voltage polarity.
If I had to do this, I would make up two small power supplies to run the driver circuits. The one for the negative leg would use the negative voltage as its ground reference; the other would use convertional ground and run a floating gate driver. I would use optocouplers to pass drive signals to the driver circuits.
I would prefer to use a conventional H bridge design, though. The hardware is readily available, and there is only one voltage to avoid.
  #10
Old 02-02-2007, 06:18 PM
Default
thanks for the reply,
Please correct me if I'm wrong. I've been surfing on the net to see if there are similar cases (+inverters +igbt +negative +rail) What I've found out is almost all the industrial ac motors rectify three phase voltage and they connect the mid point to the ground. It is kind of resonable otherwise you would only get the half of the rectified voltage, wouldn't you. Yet for all those industrial applications I dont think they have power transformers to shift the voltage. So its strange that there is no mention of driving those low side igbt's which run under the negative voltage. It seems like I'm missing something but what
Tags
Related Site Pages
Section Title
Worksheet Latch circuits
Worksheet Basic logic gate troubleshooting
Worksheet CMOS logic gates
Worksheet TTL logic gates
Worksheet Basic logic gates
Worksheet Insulated gate field-effect transistors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Basic gate function : Digital Integrated Circuits
Textbook Insulated-gate field-effect transistors (MOSFET) : Solid-state Device Theory
Textbook CMOS gate circuitry : Logic Gates
Similar Threads
Thread Thread Starter Forum Replies Last Post
Half Bridge Inverter 10KVA sachin c The Projects Forum 1 12-19-2013 02:28 PM
H Bridge or half H bridge to control thyristors davidhills The Projects Forum 0 11-14-2013 09:11 AM
High voltage half Bridge mosfet problem. iamhere The Projects Forum 22 07-12-2009 07:50 AM
PWM motor controllers, Half bridge, no bridge, etc HellTriX General Electronics Chat 1 04-19-2008 03:16 AM
H Bridge High Side Mosfet Driver bigbigblue General Electronics Chat 31 09-07-2007 10:28 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
