All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-26-2010, 06:31 AM
b2386 b2386 is offline
Junior Member
Default Can two bridge rectifiers with varying voltages be connected in parallel?
I have two different AC voltage sources that produce randomly varying AC voltages from 2-3 volts (not necessarily in unison). I have a basic bridge rectifier circuit connected to each voltage source. Assuming no voltage drop across the bridge rectifiers, I will have two DC voltage outputs varying from 2-3 volts. Can I put these two DC voltages in parallel?
  #2
Old 11-26-2010, 03:30 PM
retched's Avatar
retched retched is offline
Default
Why would you assume no voltage drop across the bridge rectifiers?
You should most DEFINITELY count on voltage drop, especially at such small voltages.
You are going to lose 1.4 or more volts across each bridge.
As for paralleling 2 different voltages, no you can't. They will fight.
You might consider a summing amplifier to add the two voltages together.
You really need to get the current into the equation. That will affect the voltage drop across the bridges also.
You may need to sum them to get a usable voltage.
__________________
-rm-
  #3
Old 11-26-2010, 03:57 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
How much current are you expecting from your AC voltage sources?
To minimize the voltage drop across the bridge, consider using Schottky diodes rated for the expected current. For even less voltage drop, consider synchronous rectification, where MOSFETs are used as "ideal diodes".
If you connect the two outputs in parallel, you will likely have problems. If you connect them in series, you will be OK.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #4
Old 11-26-2010, 04:43 PM
Junior Member
Default
lol, the reason I said assume no voltage drop was only because it's effect was not really relevant to my original question of could these two DC voltages be connected in parallel. I am using schottky diodes so the actual voltage drop will be around 0.5V in total.
  #5
Old 11-26-2010, 04:45 PM
retched's Avatar
Default
So are you set? Or did you need further clarification?
__________________
-rm-
  #6
Old 11-26-2010, 05:40 PM
Junior Member
Default
I think I got it. If I put two or more of these rectifiers in parallel, the smoothing capacitors of each rectifier will be in parallel and at any given time, the capacitors at a higher voltage will begin charging the capacitors at a lower voltage. I am assuming this is not what I want.
On a side note, let's say I have ten of these AC voltage sources described in my previous post. They have random phases so summing before rectification is not really an option. What are my options for getting a 3V DC output voltage from this entire system? I can't use transistors...
  #7
Old 11-26-2010, 07:49 PM
tom66 tom66 is offline
Default
What will happen is the AC input with a higher voltage will provide almost all of the current; it will effectively choose the maximum between two sets of voltages. See image. The two demo waveforms are 45 degrees out of phase.
Code:
$ 1 5.0E-6 10.20027730826997 53 5.0 50
d 464 240 528 176 1 0.805904783
d 400 176 464 112 1 0.805904783
d 400 384 464 320 1 0.805904783
d 464 448 528 384 1 0.805904783
w 464 288 576 288 0
w 576 80 464 80 0
w 464 80 464 112 0
g 464 240 464 256 0
w 576 288 576 80 0
d 464 240 400 176 1 0.805904783
d 528 176 464 112 1 0.805904783
d 464 448 400 384 1 0.805904783
d 528 384 464 320 1 0.805904783
w 464 320 464 288 0
g 464 448 464 464 0
w 528 384 560 384 0
w 400 384 368 384 0
w 368 384 368 512 0
w 560 384 560 512 0
v 368 512 560 512 0 1 40.0 5.0 0.0 0.0 0.5
w 576 288 656 288 0
r 656 288 656 368 0 100.0
g 656 368 656 384 0
v 368 48 560 48 0 1 40.0 5.0 0.0 0.7853981633974483 0.5
w 560 48 560 176 0
w 368 48 368 176 0
w 368 176 400 176 0
w 528 176 560 176 0
o 20 64 0 34 5.0 0.025 0 -1
o 23 64 0 35 10.0 0.05 1 -1
o 19 64 0 35 10.0 0.1 2 -1
Select All
Paste this into http://www.falstad.com/circuit.
This can be expanded to many bridges. Due to how diodes work, it will work like an N-input OR gate.
File Type: png Screenshot-Circuit Simulator v1.5m-1.png (17.7 KB, 10 views)
Tags
Related Site Pages
Section Title
Worksheet Basic AC-DC power supplies
Worksheet Rectifier circuits
Textbook AC bridge circuits : Ac Metering Circuits
Textbook AC voltmeters and ammeters : Ac Metering Circuits
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Video Lecture Power Supplies - Applications - Diodes and Diode Circuits
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Rectifier/filter circuit : Discrete Semiconductor Circuits
Textbook Half-wave rectifier : Discrete Semiconductor Circuits
Textbook Rectifier circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
rectifiers Parallel input Ele General Electronics Chat 5 03-06-2010 08:26 PM
Replacing the 4 batteries connected in parallel? cardiology General Electronics Chat 1 02-11-2010 04:24 PM
Bridge Rectifier Problem when connected to Wall Power Outlet richeek.arya General Electronics Chat 21 11-10-2009 08:00 PM
Capacitors connected parallel with power source TO2 General Electronics Chat 7 06-20-2009 11:49 AM
multiple rectifiers in parallel mckaype The Projects Forum 1 06-01-2006 06:52 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
