All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-20-2010, 07:16 PM
oupulino oupulino is offline
Default 12 5mm led to 12V DC 1000mA adapter
Hi can someone help me out how to connect 12 X 5 mm leds on 12 V DC 1000mA adapter here is spec for led they are pre wire with own resistor any wiring diagram is really appreciated
The led are rated for 12V
The resistor = 470 ohm 1/4W.
The LED voltage = 3.0v - 3.4v
The LED amp = 20mA
If the adapter output = 1000mA then it is sufficient to connect more than 40 LED together. How to do it Im using it as a background
  #2
Old 11-20-2010, 07:24 PM
tom66 tom66 is offline
Default
I use this website: http://led.linear1.org/led.wiz
It suggests putting 3 LEDs in series in 4 parallel chains. Each has a 150 ohm resistor in series to limit current.
Be careful with your wall wart. Very likely it isn't outputting 12V - it is probably unregulated, basically a transformer, diodes and a capacitor. In order to get it to output 12V you need to load it down with the maximum 1A - otherwise the output can be as high as 18V, which will overheat your LEDs.
Perhaps try a switching power supply which should keep 12V or thereabouts no matter what the load, up to 1A. CUI supplies are quite popular. Ideally, chose a 9V supply, which would allow you to put 3 LEDs in series with no resistors maximising efficiency.
Also you might want to follow the buck regulator thread where a single LED supply is being designed, however it should still work with series LEDs.
  #3
Old 11-20-2010, 08:21 PM
Default
the power adapter is Regulated and this led are pre wire so each led has already resistor 470 ohm 1/4W.How to wire 12 of them to one 12V DC 1000mA adapter do I have to add another resistor or cut of existing resistor
  #4
Old 11-20-2010, 08:37 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
Just wire them all in parallel.
Since each LED-resistor string will draw ~20mA current, you can connect up to 1000mA/20mA = 50 pairs.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
  #5
Old 11-21-2010, 06:02 AM
Default
Thank you very much it work I was posting every were about this issue and only you resolve it properly other recommended replacing resistor,cutting of existing ones all nine yards long story
Thank you one more time SgtWookie
  #6
Old 11-24-2010, 05:00 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
LEDs, 555s, Flashers, and Light Chasers
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Tags
Related Site Pages
Section Title
Video Lecture Transformers (Part 1) - Inductors,Capacitors,Transformers
Worksheet Design Project: LED stroboscope
Worksheet Design Project: Dual-output AC-DC power supply
Worksheet Design Project: AC-DC power supply
Worksheet Series-parallel DC circuits
Worksheet Electrical connections
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Vacuum tube audio amplifier : Discrete Semiconductor Circuits
Textbook Transistor as a switch : Discrete Semiconductor Circuits
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
9v DC to 12v DC? killercripple General Electronics Chat 39 04-25-2010 01:15 AM
LED office-desk lighting system kdaffolder The Projects Forum 1 08-04-2009 07:43 AM
help my dc adapter keeps dying Sred General Electronics Chat 8 06-07-2009 01:30 AM
Create 12v Lead Acid charger with 12v adapter BlackHawk9 General Electronics Chat 4 11-19-2008 06:02 PM
12v Aquarium fan, led moonlight, top off coolfish5 The Projects Forum 9 03-10-2007 07:54 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
