All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-19-2010, 05:28 AM
wind_blast942 wind_blast942 is offline
Junior Member
Default Convert a D flip flop into JK
I am confused on how to systematically convert a D flip flop into a JK flip flop
J K Q Q+ D
0 0 0 0
0 0 1 1
0 1 0 0
0 1 1 0
1 0 0 1
1 0 1 1
1 1 0 1
1 1 1 0
I am able to merge the characteristic and excitation table together, but since there are some values where Q to Q+ changes from 1 to 0, and there is no excitation
possible for a d flip flop to effect this change.
In this case what should i do?
  #2
Old 11-19-2010, 08:27 AM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
A FF is always excited by its input. As long as the clock is pulsing it will change its state according to the J K and Q (or D and Q) data.
What you need to do is extract the Boolean function Q+=F(J,K,Q) and drive its output in the D input of your FF. Since a D FF will drive its next state where its D input is, you will be able to control the FF by changing that input.
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
  #3
Old 11-19-2010, 08:53 AM
Junior Member
Default
By solving Q+ = f(J,K,Q), i get J AND (NOT Q); so does it mean i connect this expression into the D ff?
But in this case wouldn't K not affect the flip flop at all?
  #4
Old 11-19-2010, 11:36 AM
Georacer's Avatar
Super Moderator
Default
Maybe you need to check again your Karnaugh map solution. Try it once more.
__________________
  #5
Old 11-19-2010, 11:49 AM
Junior Member
Default
My mistake it should be Q+ = (J . |Q) + (|K . Q)
So to confirm will the circuit look like this? With Q as the output and J,K as the input?
  #6
Old 11-19-2010, 12:27 PM
Georacer's Avatar
Super Moderator
Default
Still no...
Are you sure you 're making this K-map?
I suggest a revision on your K-maps.
__________________
  #7
Old 11-19-2010, 01:12 PM
Junior Member
Default
But doesn't this K-Map give: (J . |Q) + (|K . Q) ?
  #8
Old 11-19-2010, 03:38 PM
Georacer's Avatar
Super Moderator
Default
Yes, it does. My bad.
F=JQ'+K'Q is the correct answer.
__________________
Tags
Related Site Pages
Section Title
Video Lecture JK Flip-Flop - Digital
Worksheet Counters
Worksheet Flip-flop circuits
Video Lecture Counters - Digital
Textbook Serial-in/serial-out shift register : Shift Registers
Textbook Finite State Machines : Sequential Circuits Counters
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook Synchronous counters : Sequential Circuits Counters
Textbook Asynchronous flip-flop inputs : Multivibrators
Textbook The J-K flip-flop : Multivibrators
Similar Threads
Thread Thread Starter Forum Replies Last Post
Submission: Sequential Circuits Georacer Feedback and Suggestions 17 10-31-2010 04:07 AM
SR Flip Flop using D Flip Flop and other logic jegues Homework Help 11 10-22-2010 03:14 PM
Help: 555 to counter to mux to J-K flip flop th1alb General Electronics Chat 2 12-01-2009 08:00 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
