All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-11-2010, 02:21 PM
spinnaker's Avatar
spinnaker spinnaker is offline
Default Rent or borrow ESR Meter in Pittsburgh area?
Does anyone know where I can rent (at a reasonable cost) or borrow an ESR meter in the Pittsburgh area?
A suggestion in this thread said I might have a bunch of bad filter caps in my non working Tek scope. It would probably be just as easy to just replace them since they probably need to be replaced anyway but it would be nice to know if the caps are my problem. Where can I get one of these things aside from shelling out the $$$ to buy one.
I know I can build one with another scope, a function generator or a 555 timer (and I guess even a PIC which I have on hand). But I do not have a another scope.
  #2
Old 11-11-2010, 02:57 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
Why not make one yourself?
Here is a schematic with a PCB:
http://kakopa.com/ESR_meter/index.html
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 11-11-2010, 03:07 PM
spinnaker's Avatar
Default
Quote:
Originally Posted by bertus View Post
Bertus
The problem with that is I do not have most of those parts on hand. And I would need to have confidence that I had it working right.
  #4
Old 11-11-2010, 03:20 PM
bertus's Avatar
Super Moderator
Default
If you would buy one, what would be the budget?
Here is a kit for $79 or completerly assembled for $109:
http://www.anatekcorp.com/blueesr.htm
Bertus
__________________
  #5
Old 11-11-2010, 04:01 PM
spinnaker's Avatar
Default
Bertus
Yeah I have seen them for around $80 built.
http://cgi.ebay.com/In-Circuit-Capac...item3f04b2d609
  #6
Old 11-11-2010, 04:39 PM
someonesdad someonesdad is offline
Default
For us hobbyists, measuring ESR usually involves observing the change of a voltage Vo in the attached circuit when the capacitor under test (modeled by the pure capacitance and the ESR (equivalent series resistance) in the dashed box) is inserted in the voltage divider circuit. Two test leads are often run from the capacitor connection points to allow in-circuit testing. The method is:
Set V to the voltage and frequency you want to test at. Measure Vo with no capacitor attached; call the measured value V1. Then attach the capacitor to be tested and measure Vo again; call this value V2. Then an estimate of the ESR of the capacitor is made from the ratio V2/V1.
The lower the ratio V2/V1, the lower the ESR is -- and the capacitor's impedance is better at shorting out the voltage across R2. An ideal capacitor would short out the voltage completely, making the voltage V2 zero.
You calibrate your ESR checker with some resistors -- say, 0.1, 1, and 10 ohms. You substitute these for the capacitor and measure their voltage ratios just like you would for a capacitor. You can plot R versus the voltage ratio to let you estimate a capacitor's ESR from the graph.
So, if you wanted to make a practical checker, what should you use for V? A function generator is the usual choice or you can make your own oscillator. Another choice could be a 6.3 VAC filament transformer. This will test at line frequency; the usual test for filter caps is at twice the line frequency because they're filtering a full-wave rectified signal. But this is an order-of-magnitude test, so line frequency should be fine. Commercial ESR testers often test at 1, 10, and 100 kHz besides line and twice-line frequencies.
You'll want to choose the resistors R1 and R2 to ensure you put appropriate voltages across the capacitor. If you're doing in-circuit testing, the voltages should be kept low enough to avoid making any semiconductor junctions conduct. Possible starting values are R1 = 1 kΩ and R2 = 5 Ω. Use what you have on hand. You can use a DMM to measure the voltages if you don't have a scope as long as you keep the frequency of V in the DMM's bandwidth. This is a comparative and screening measurement, so accuracy of measurement tools isn't all that important.
I haven't tried this with a filament transformer, but it should work OK for big filter caps. I have used the method with a function generator and a scope and it works well for frequencies in the 10 kHz - 100 kHz range.
Added in edit: Make sure the capacitor is discharged before you measure it. Also, a shorted capacitor will appear to be a good capacitor with this test, so you might want to check a vanishing-ESR capacitor with a DC resistance measurement.
  #7
Old 11-11-2010, 05:06 PM
spinnaker's Avatar
Default
Any reason it has to be 6.3 VAC?
The shack has a 12V CT .
They have a 12.6 but does not say if it is CT.
I also have a PIC on hand. Could I just use it? What frequency should I use for a pulse?
What is the safest way to discharge those big caps?
  #8
Old 11-11-2010, 05:51 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
The BlueESR is awesome. I would suggest getting the kit, it is really hard to do "wrong". I use mine nearly daily, and have nothing bad to say about it!
  #9
Old 11-11-2010, 08:08 PM
spinnaker's Avatar
Default
Quote:
Other than getting the caps on this scope tested. I can't imagine what I would use it for. I will mainly be working with digital, mcus and such. It is hard to justify spending $80 on something I will probably not use.
  #10
Old 11-11-2010, 08:23 PM
thatoneguy's Avatar
Default
I use it a lot of the time as a battery tester/matcher. It is very accurate and can tell you the state of charge on the battery.
It also lets you know the ESR of a cap (obviously), and can alert you to some problems in an etched PCB track from the ability to measure very low resistance.
With digital stuff, you'll be working with power supplies, and being able to go through the whole supply in a few seconds to rule out a lot of cap related issues speeds things up.
If you don't use it that often, no need to get one, but I was amazed at the uses I found for an AC Ohmmeter.
Tags
Related Site Pages
Section Title
Textbook What is a meter? : Dc Metering Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
Does my meter measure true RMS, AC+DC? The Electrician General Electronics Chat 8 02-21-2010 02:51 AM
Where can you rent mains power meter? alphacat General Electronics Chat 2 01-31-2010 04:51 PM
What do you think of this Cap & ESR meter? timarlop The Projects Forum 6 01-21-2010 07:16 AM
understanding capacitor ESR ratings DaveH General Electronics Chat 23 10-04-2009 02:46 PM
ESR Meter Test dj54557 Homework Help 0 10-20-2008 03:52 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
