All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-08-2010, 04:49 PM
picstudent's Avatar
picstudent picstudent is offline
Member
Default Triac based heater control
I need to control a 500W cartridge type heater as a part of PID temperature control.
AS far as I know Phase control and Pulse skip modulation or burst mode control are the available options.
Which is the best mode for heater control?
At this wattage, Triacs or Solid state relays, which are more feasible?
  #2
Old 11-08-2010, 05:25 PM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
I would not use a relay, regular, or solid state for continuous on/off operation. They have a finite mechanical life and will fail eventually due to exceeding the operational life of the on/off mechanism. PWM rates are 100's to 10,000's of cycles per second. The relay would be dead in a day or a few weeks at that freq.
Use simple SCR's.
__________________
I'm too old.
The Following User Says Thank You to Kermit2 For This Useful Post:
picstudent (11-12-2010)
  #3
Old 11-15-2010, 02:36 PM
Tahmid's Avatar
Tahmid Tahmid is offline
Location: Cornell University, Ithaca, New York, USA (from Dhaka, Bangladesh)
Default
At 500W switching application for power control, the way to go is solid-state. You can use both phase-angle control and pulse skipping modulation. 500W power is not very high, and here triac can be used with no problem, but SCR is safer no matter what, not to say that triacs wouldn't do the job. I think upto a kW, triacs are fine, but SCRs are just safer because of no chance of faulty triggering or misfiring.
Hope this helps.
Tahmid.
__________________
পৃথিবীর সর্বোচ্চ দালানও প্রথম ইট বসানো থেকেই তৈরি হয়েছে।
The tallest building in the world starts from the first brick.
The Following User Says Thank You to Tahmid For This Useful Post:
picstudent (11-15-2010)
Tags
Related Site Pages
Section Title
Worksheet Latch circuits
Worksheet Thyristors
Worksheet Thyristor application circuits
Worksheet Signal modulation
Textbook Optothyristors : Thyristors
Textbook The TRIAC : Thyristors
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Textbook Solid-state relays : Electromechanical Relays
Textbook Contactors : Electromechanical Relays
Textbook Thyristors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Optoisolated Triac Water Heater Controller moniker The Projects Forum 5 06-20-2010 11:25 PM
Triac gate control Cbaz Homework Help 6 02-11-2010 05:46 PM
Triac gate control Cbaz General Electronics Chat 1 02-11-2010 02:15 PM
Need help for a dawn/dusk LED circuit malaybiswas The Projects Forum 24 03-04-2009 04:19 PM
car temp control (fuel heater + ventilation control) rasto The Projects Forum 11 12-09-2008 12:58 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
