All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-08-2010, 03:05 PM
aboutsc aboutsc is offline
Default MOD-60 counter with stop/start and reset buttons
HI all
I am given an assignment by my lecture. We are using two 74LS93N(4 bit binary counter) ICs to build a 60 seconds stopwatch. I have no problem building MOD-60 counter from 00 - 59 and it will reset to 00 when it hits 60. I have connect the these two 74LS93N to two 7 segment LED common Anode. I use MOD-6 and MOD-10 to come up with the MOD-60 counter.
However, I do not know how to add in stop/start and reset buttons. The reset button switch will clear or reset the mod-60 counter to 00 when activated. ie, 00 until it is started again through the use of the start/stop switch.
If the mod-60 value is running , activating the start/stop switch will stop the counter at its current count value, ie, 40, which indicates a time lapse of 40 seconds from the start. Reactivating this same switch will cause the mod-60 counter to resume from this previously stopped value.
We are given one 74LS00 and one 74LS32 as well.
PLEASE DO HELP ME!!!
THANKS
CURTIS
P.s I have read through another post which had been posted here for quite sometime. But it is different from my case.
  #2
Old 11-08-2010, 05:11 PM
beenthere's Avatar
beenthere beenthere is offline
Default
It would be interesting to see your schematic. Achieving a mod6 and mod 10 count from binary counters using only one 'LS32 sounds challenging.
If you have the data sheet for an 'LS93, you will notice some reset pins. You could also reset on a count of 3Bh
__________________
First comes the hardware, then the software.
  #3
Old 11-08-2010, 07:14 PM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
As for the stopwatch function, you could filter the clock pulses from reaching the IC with a AND or NAND gate.
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
  #4
Old 11-08-2010, 09:58 PM
djsfantasi's Avatar
djsfantasi djsfantasi is offline
Default
What are you using for a clock? I assume you are using the MR1 and MR2 inputs to implement your Mod n functionality. The 74ls32 can be used to also allow an external signal (reset switch) or the data signals to reset your chips. You can isolate the first flip flop of the 'ls93 used for the Mod 6 counter and use it as a latch for start/stop, since you only need the last three outputs for Mod 6. This latch can be used to gate the clock into the Mod 10 counter. You have the 'ls00 for gating the clock pulses.
  #5
Old 11-10-2010, 02:17 PM
djsfantasi's Avatar
Default
Have you had any success? Please let us know.
  #6
Old 11-13-2010, 05:41 PM
scope scope is offline
Default
how do you use the 74ls32 to allow a switch to reset the the ics?
  #7
Old 11-14-2010, 07:04 AM
Default
Basically my friend came out with this. It does work. But I want it to recount again from 00-59.
When I give a Logic low signal to the start/stop button, the counter will start counting and reset the whole counter when it hits 59. After that it will stop at 00 and wait for the next push to Logic low.
Thanks you all for your reply!!!
CHEERS
CURTIS
  #8
Old 11-14-2010, 01:13 PM
beenthere's Avatar
Default
Zowie - where did you scare up the 74F00? You will need triple decoupling caps to get your counter to run with that glitching monster in there. Hope you remembered to tie those unused inputs to ground.
__________________
  #9
Old 11-14-2010, 03:52 PM
Default
Quote:
Hope you can explain more on this. I do not really understand this.
  #10
Old 11-14-2010, 06:11 PM
beenthere's Avatar
Default
&4F logic is very old. It was done in an attempt to make logic that could clock faster than the standard 74xx and 74LSxx logic. The output stage exhibits a goodly amount of shoot through, so the Vcc bus handles lots of current and switching noise (big current spike with every gate output transition).
For all logic whatever, unused inputs that are allowed to float will do so right at the operating level, causing the output to oscillate. The oscillations may cause the IC to fail. Since you are dealing with TTL, you can tie inputs to ground, or else pull them up to Vcc with a resistor (not needed to CMOS). Use 20K for 74LSxx, and 4.7K for 74Fxx.
__________________
Tags
Related Site Pages
Section Title
Worksheet Counters
Worksheet Flip-flop circuits
Worksheet Latch circuits
Worksheet Multiplexers and demultiplexers
Worksheet Electromechanical relay logic
Video Lecture Representative System (Part 3) - Executing a Program - Microprocessors
Video Lecture Asynchronous Counters - Digital
Textbook Ring counters : Shift Registers
Textbook Asynchronous counters : Sequential Circuits Counters
Textbook LED sequencer : Digital Integrated Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
At89s51 microcontroller based annunciation system with led display varalakshmisethepalli Embedded Systems and Microcontrollers 0 03-14-2010 03:10 PM
Mod 16 syncronous counter NOSI Homework Help 1 10-21-2009 12:02 PM
Mod 12 counter ambarish Homework Help 1 05-15-2009 11:33 PM
mod 6 up down counter magik5 Homework Help 3 10-03-2008 02:18 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
