| Embedded Systems and Microcontrollers Discussion forum for projects and working with embedded systems and microcontrollers (FPGAs, PICs, AVRs). Get help with hardware issues and embedded programming. |
Thread Tools | Display Modes |
#1
I am developing Caller Line Indentification
It has to be interfaced with 8051 and display the telephone number in monitor. Which chip shall I use it Is MT8843 from mittel can be used It should compatable for DTMF & FSK . The present which I developed using MT8888 it is working in one exchange but other exchagne it not working this is to reference as per country India so i other chip to test it Kinldy help me |
#2
This is a way test the decoder circuit you have since the output goes to a PC.
http://www.raphnet.net/electronique/cid/cid_en.php After that's working you can feed the data stream to an MPU then a display. |
#3
Any chip for MF( Multi frequency ) decoding in telecom I could not able to find it out I think it is a old system of transmiting CLI. |
#4
can u give me caller ID circuit using discrete componets along with Up interfacing
Thanks |
| Tags |
| 8051, application, clip, interface |
Related Site Pages
| Section | Title | |||
| Worksheet | Digital display circuits | |||
| Worksheet | Multiplexers and demultiplexers | |||
| Textbook | Decoder : Combinational Logic Functions | |||
| Textbook | Clipper circuits : Diodes And Rectifiers | |||
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| i2c interface question | martin_k | Programmer's Corner | 2 | 07-28-2009 02:06 PM |
| need help with a 8051 mcu project | G-Unit | Embedded Systems and Microcontrollers | 10 | 11-03-2007 01:40 PM |
| with 8051 send to LCD from .txt file | karayel_kara | Embedded Systems and Microcontrollers | 2 | 01-06-2007 03:59 AM |
| Need help ! How to interface 68HC11A1P with the 16*2 character lcd display?? | gab102001 | The Projects Forum | 4 | 11-21-2006 03:50 AM |
| Thread Tools | |
| Display Modes | |
