I tore apart an old floppy disk drive and built a little DIY generator. It is a proof in concept to power a propeller clock.
I am successfully generating around 12 V but only at 4.5 ma. I think that is hardly enough to power the UC not to mention multiple LEDs.
My load was a 220 ohm resistor because that is what I had sitting on my work bench.
I chose the 2200 uf cap because that was pretty much the only cap I had on hand.
Currently I am spinning the generator with an electric hand drill and the mechanical coupling between the drill and the magnet plate is not the best but I do seem to get it spinning pretty well.
I do plan to use a HDD motor to spin everything but unless I can get the current up the generator idea is not going to work.
Any ideas other than to get a bigger generator?
