All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 11-04-2010, 01:33 PM
MrRockchip MrRockchip is offline
Junior Member
Default Problem with transistors
I have 5 problems, which are similar to each other.
But I need an example. Please, help me to solve this one:
(and I will solve the remaining 4 by myself)
  #2
Old 11-04-2010, 01:52 PM
Kermit2's Avatar
Kermit2 Kermit2 is offline
Default
I'm a long time out of school, but I think at least one more piece of info will be needed to answer that. Yes it will either conduct or not conduct at the extremes, but I believe the transistors gain must be known to get an expression for the output.
__________________
I'm too old.
  #3
Old 11-04-2010, 02:32 PM
Junior Member
Default
If don't count the thermal current, then you have all the necessary data.
  #4
Old 11-04-2010, 03:04 PM
Kermit2's Avatar
Default
well like I said, I'm out of school a long time, so carry on smartly then soldier
__________________
I'm too old.
  #5
Old 11-05-2010, 02:22 AM
hobbyist hobbyist is offline
Default
Take a look at your circuit, the bottom transistor has it's base emitter junction conducting because it is forward biased, however the collector is not biased at all, due to the top transistor being reversed biased, and not conducting.
So your voltage is the voltage of a open collector transistor with full base voltage applied.
This is just a somewhat educated guess.
Tags
Related Site Pages
Section Title
Worksheet Class B BJT amplifiers
Worksheet Bipolar junction transistors in active mode
Worksheet Bipolar junction transistor theory
Video Lecture Transistor Biasing (cont) - Transistors and Transistor Circuits
Video Lecture Transistor Biasing - Transistors and Transistor Circuits
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Biasing techniques : Bipolar Junction Transistors
Textbook The common-collector amplifier : Bipolar Junction Transistors
Textbook Meter check of a transistor : Bipolar Junction Transistors
Textbook Bipolar junction transistors : Solid-state Device Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
AD594 Thermocouple Interference and Ground Capacitance Problem delmasli General Electronics Chat 10 02-17-2011 04:24 PM
M2 ATX chinese clone psu problem ViperRunner General Electronics Chat 68 03-01-2010 10:31 PM
Z transform problem mattc82 Math 11 12-03-2009 04:45 PM
Laptop screen problem mentaaal General Electronics Chat 16 07-28-2009 02:04 PM
Circuit problem, help please! true bypass General Electronics Chat 12 05-19-2008 07:28 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
