All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 01-21-2007, 01:05 AM
unlisted unlisted is offline
Junior Member
Post Diode problem
Hey guys,
I am looking for a point in the right direction for this problem.
The problem asks for the value of R for which the voltage across the resistor is 40mV. I assume I need to workout the current passing through the resistor. Since the resistor is in series with D1, which is in parallel with D2 the current should be divided. Once I have the current I can use Ohm's law to find R.
So I think what I need to find is the current passing through D1 and R.
  #2
Old 01-21-2007, 02:17 AM
Ron H's Avatar
Ron H Ron H is online now
E-book Developer
Default
I know how to solve this, and it involves the diode equation. Since it's homework, I won't give you the answer, but I can give you some clues.
But first - have you been exposed to the diode equation? If so, tell us what it is.
  #3
Old 01-21-2007, 03:07 AM
Junior Member
Default
Thanks for the help.
I have been exposed to the diode equation i = Is[exp(v/nVT - 1)]
At room temperature VT = .025V
n is 1, or 2, but we are not given a value for n.
  #4
Old 01-21-2007, 03:17 AM
Ron H's Avatar
E-book Developer
Default
In order to solve this, you first have to solve for n. It is not 1 or 2, but it is somewhere in between. You can solve for n from the information given.
After you solve for n, you can then solve for the current through the two diodes, and then, of course, you can solve for R.
If you get stuck, post your efforts here and I'll give you some more clues.
Hint: the "-1" in the equation is insignificant at the current levels you are working with. You may already be aware of this.
  #5
Old 01-21-2007, 04:02 AM
Junior Member
Default
Ok, I solved for n and Is, and got an equation for i.
The V given in the problem statement is the drop across R, right? So
I can't just plug that into my diode equation. Do I need to first solve
for the drops across the diodes?
  #6
Old 01-21-2007, 04:30 AM
Ron H's Avatar
E-book Developer
Default
You don't need Is. Think about this:
I1~Is*e^(v1/nVt)
I2~Is*e^(v2/nVt)
therefore,
(1) I1/I2=e^((v1-v2)/nVt)
Note that Is has fallen out of the equation.
From this relationship, and the information about the diodes given in the problem, you can find n.
Once you find n, remember that you know that in the actual circuit, v1-v2=40mV. From this fact, and using eq. (1), you can find the currents through the two diodes.
Another hint: Naperian logarithims are required to solve for n, and again for I1 and I2.
  #7
Old 01-21-2007, 04:48 AM
Junior Member
Default
I used the natural log to find n. Does v1-v2=40mV come from Kirchoff's voltage law?
  #8
Old 01-21-2007, 03:18 PM
Ron H's Avatar
E-book Developer
Default
It comes from the fact that the anodes are tied together, the cathode of D2 is at zero volts, and the cathode of D1 is at 40mV. Therefore (VD2-VD1)=40mV. I guess that's Kirchhoff's voltage law. When you've been an engineer for 40 years, the names of the laws (in my case, anyway) become irrelevant. Who else had a voltage law?
Did you understand the ratio equation, and why Is falls out of the equation? I suppose you could find Is, but you don't need it.
  #9
Old 01-21-2007, 06:08 PM
Junior Member
Default
I understand the ratio equation, that is basically how I solved for n. I just don't get the v1-v2 = 40mV. To me, the two diodes look like they are hooked up in parallel. In which case they should share the same voltage drop, right?
Ok, assuming v1-v2=40 mV I am still unclear on how to find the currents through D1 and D2. I'll look back through the post and see if I can work it out.
Wow, 40 years? Ever think about teaching this stuff?
  #10
Old 01-21-2007, 07:08 PM
Ron H's Avatar
E-book Developer
Default
I work full time as an engineer. I don't have the time or the inclination to teach (except on forums like this).
How can you think the diodes are in parallel when R has 40mV across it? D1 obviously (to me, anyway) has 40mV less across it than D2.
If you accept that, do you understand where this equation comes from?
ln(I2/I1)= (v2-v1)/nVt
You can solve for (I2/I1).
Your other equation is (I2+I1)=10ma (from the schematic).
You now have two simultaneous equations. Solve for I2 and I1.
Tags
Related Site Pages
Section Title
Worksheet Active filters
Worksheet Precise diode circuits
Worksheet Regulated power sources
Worksheet Bipolar junction transistors in active mode
Worksheet Zener diodes
Worksheet Clipper and clamper circuits
Worksheet Rectifying diodes
Worksheet Parallel DC circuits
Textbook Current mirrors : Bipolar Junction Transistors
Textbook Special-purpose diodes : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
zener diode value hacksaw General Electronics Chat 13 03-14-2009 09:04 AM
EFI Fuel Relay Problem akajee The Projects Forum 4 01-26-2008 08:18 PM
troubleshooting. trying to identify a component and problem John68 The Projects Forum 5 12-13-2007 10:01 PM
MOSFET problem chintu84 Homework Help 4 11-18-2006 09:02 AM
Series Parallel Sinusoidal AC Curcuit Problem thndrdrag Homework Help 2 11-16-2006 09:05 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
