All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-26-2010, 12:35 PM
chudiandeyu chudiandeyu is offline
Junior Member
Default Circuit for Hall effect sensor
Hello
I recently bought a linear Hall effect sensor for measuring current, but I don't know how to make the circuit to measure the current, could anybody help me with this? Please tell me the circuit.
Thank you very much!
  #2
Old 10-26-2010, 12:39 PM
bertus's Avatar
bertus bertus is online now
Super Moderator
Default
A lot of information on Hall sensors can be found in the links from this page:
http://www.educypedia.be/electronics/sensorshall.htm
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #3
Old 10-26-2010, 01:49 PM
Junior Member
Default
@bertus
Thank you. And after I measured the output voltage of the hall effect sensor, how can I know the current in primary wire?
  #4
Old 10-26-2010, 01:55 PM
Kermit2 Kermit2 is offline
Default
http://www.electronics-tutorials.ws/...ll-effect.html
Second page; scroll down just a tiny bit.
__________________
I'm too old.
  #5
Old 10-26-2010, 01:57 PM
beenthere's Avatar
beenthere beenthere is offline
Default
The device should have a data sheet that states the sensitivity of the sensor. Even so, you will probably need an ammeter to help calibrate the Hall effect sensor output.
__________________
First comes the hardware, then the software.
  #6
Old 10-26-2010, 04:44 PM
mcgyvr mcgyvr is offline
Default
You need to either use a micro to do the scaling or have some manual scaling factor (for example 10mV=1A)
I've got a project that uses a hall sensor.. calibration is a pain. Mine measures up to 600 Amps DC. Sensor spaced approx. 3/16" off a copper bus bar.
  #7
Old 10-27-2010, 07:38 AM
Junior Member
Default
How can I know the scaling factor?
  #8
Old 10-27-2010, 08:00 AM
Junior Member
Default Block diagram for Hall effect sensor
Does anybody know the block diagram of Honeywell CSLA2EL Hall effect sensor ?
And how to use this sensor to make a circuit for measuring current?
And how can i know the relation between the output voltage and primary current?
Thank you!
  #9
Old 10-28-2010, 12:19 AM
hgmjr's Avatar
hgmjr hgmjr is offline
Super Moderator
Default
Greetings chudiandeyu,
I have merged both of your posts since they appeared to be identical.
hgmjr
  #10
Old 10-28-2010, 10:28 AM
bertus's Avatar
Super Moderator
Default
All information on sensitivity and size are in the attached datasheet.
Bertus
File Type: pdf Hall_sensor_csla_series_linear_current_sensor.pdf (395.1 KB, 41 views)
__________________
Tags
Related Site Pages
Section Title
Worksheet DC transducers
Textbook Power measurement : Ac Metering Circuits
Worksheet DC metrology
Similar Threads
Thread Thread Starter Forum Replies Last Post
hall effect sensor circuit diagram jayanthyk192 General Electronics Chat 4 04-28-2010 07:23 PM
555 timer circuit for servos MoC General Electronics Chat 4 03-18-2010 12:33 PM
mega atmel 16L Circuit to use with ultrasonic sensor nagisons Embedded Systems and Microcontrollers 0 03-06-2010 11:42 AM
Hydrogen Gas Sensor Circuit varsity_villain The Projects Forum 15 12-10-2008 03:48 PM
Sensor circuit, Flasher circuit 123456 Homework Help 11 08-03-2006 10:58 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
