All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-24-2010, 08:03 PM
iONic's Avatar
iONic iONic is offline
Default Understanding an Electric Blanket Heat Controller
I'm trying to understand just how an electric blanket heat controller works. Any insight would be helpfull.
The one I have is soley a mechanical device. A set screw determins the ability of a contact is made or broken. So how does it work? Is is based on the thermal properties of the metal used? Does it detect current flow?
All I know is that they have so much slop in the temperature of the blanket.
You turn it till the heat comes on and it gets too hot, so you turn it till the heat goes off and it gets too cold. So somewhere between the contact being turned on or off is the temperature I would be interested in and seems to be a big guessing game!
enlighten me please.
iONic
__________________
Fight piles of trials with smiles
It riles them to believe
That you perceive
The web they weave
- The Moody Blues
  #2
Old 10-24-2010, 08:05 PM
Markd77's Avatar
Markd77 Markd77 is offline
Default
There could be a bimetallic strip in there, they bend in relation to temperature.
  #3
Old 10-24-2010, 08:15 PM
BillB3857's Avatar
BillB3857 BillB3857 is offline
Default
The one I took apart many years ago had a bi-metal that also carried the current to the blanket. A combination of ambient temp and heat generated by the current opened and closed the contact.
  #4
Old 10-24-2010, 08:58 PM
thatoneguy's Avatar
thatoneguy thatoneguy is offline
Default
Here is the schematic for one:
Patent 4034185 by Northern Electric, applied for Sept 2, 1975
  #5
Old 10-24-2010, 09:05 PM
iONic's Avatar
Default
That is most likely what it is. It is 15+ years old. But since the ambient temperature is relatively stable and the metal strip is isolated (5ft +) from the actual heated blanket I would think that the current primarily is heating the metal strip. That could certainly explain the slop in temperature sensitivity of the device. Although the scale is set from 1 to 10, normal operating conditions in home keep is between 3 and 4, 3 being sometimes too cold and 4 being sometimes being too hot! What I need are some levels between 3 and 4. I guess I'm asking for too much from 15 year old technology. Need a new one based on PWM, thus settings will produce sensitive and predictable levles of heat. You could say that the "hysteresis" of the metal plate version is very wide, +/- 10 degrees F or more.
__________________
That you perceive
The web they weave
- The Moody Blues
  #6
Old 10-25-2010, 01:41 AM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
It's just timed, the higher you set the control the longer the on cycle is. Timing is provided by that bimetal strip heating and cooling.
There are protection devices inside the blanket to limit the maximum temperature only, they're rarely any sort of temp sensing device.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
  #7
Old 10-25-2010, 02:07 AM
thatoneguy's Avatar
Default
That doesn't sound as good as packing it all into once sentence, say
"VLF PWM open loop temperature control, the load having integral heat and current overload protection"
I suppose more could be abbreviated and some extra buzzword bingo type stuff could be added for extra fluffiness since we are discussing blankies.
  #8
Old 10-25-2010, 03:52 AM
marshallf3's Avatar
Default
Sad but true, I probably took one apart 50 years ago out of curiosity and when my aunt's quit working a few years ago I said I'd look at it - control system was essentially the same setup.
I suppose there is a small amount of feedback introduced from the room temperature's effect on the bimetal switch.
__________________
  #9
Old 01-19-2011, 12:46 PM
BillB3857's Avatar
Default
The current going through it. Or, in some cases, it is wrapped in an electrically insulating material and then wrapped with a nichrome wire which carries the current and acts as the heating element.
  #10
Old 01-19-2011, 12:52 PM
bertus's Avatar
bertus bertus is online now
Administrator
Default
Here is the ehow article:
http://www.ehow.com/how-does_5641870...ket-works.html
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
Tags
Related Site Pages
Section Title
Worksheet Electromechanical relay logic
Textbook Switch contact design : Switches
Textbook Switch types : Switches
Worksheet AC motor control circuits
Textbook Gas discharge tubes : Thyristors
Worksheet Switches
Worksheet Soldering
Worksheet Electrical connections
Textbook Contactors : Electromechanical Relays
Textbook Sensitive voltage detector : Dc Circuits
Similar Threads
Thread Thread Starter Forum Replies Last Post
AC Fan Motor Controller; Much Help Needed wescat The Projects Forum 22 02-10-2011 06:30 AM
MOSFET motor controller heat problem russpatterson The Projects Forum 13 06-18-2010 06:32 PM
Help understanding fan controller circuit bitrex General Electronics Chat 2 12-28-2009 09:15 PM
making PWM speed controller for Electric bike CaptainPrice The Projects Forum 41 09-25-2009 08:09 PM
1500W electric trike pwm controller broke for the third time! bob123 The Projects Forum 22 09-21-2008 06:36 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
