OP AMPS - Crossover distortion
R!f@@
Joined Apr 2, 2009
10,004
OP amps does not introduce cross over distortion in the first place.
Amplifiers classes other than class A produces cross over from it's output stage.
So a google search and read. U'll know better this way
Ron H
Joined Apr 14, 2005
7,063
LM324/358, etc., has a class B output stage, and will create crossover distortion if used with dual supplies and a grounded load.
Op amps reduce crossover distortion, with feedback, because the high open loop gain forces the output to do what it needs to to keep the voltage difference between the inputs near zero.
R!f@@
Joined Apr 2, 2009
10,004
I know tht power OPAMPS have been introduced with class B out put stage.
I was right tht the output stage introduces distortion
Audioguru
Joined Dec 20, 2007
11,248
No.
The LM358 dual opamp and the LM324 quad opamp are the first "low power" opamps. They reduce their supply power by operating the output transistors in class-B with hardly any bias current instead of in class-AB that has enough bias current to avoid crossover distortion. The class-B opamps have 3% of crossover distortion even with plenty of negative feedback and ordinary class-AB opamps have 0.003% or less distortion (one thousand times less distortion).
No.
The TL07x opamps have 0.003% distortion and the OPAx134 opamps have 0.00008% distortion. Their output transistors operate in class-AB.
I don't know any opamp that operates the output in class-A. It would melt.
Class-A amplifiers heat the entire neighbourhood even when they are doing nothing.
Audioguru
Joined Dec 20, 2007
11,248
No.
The lousy old LM358 and LM324 have such poor high frequency response that negative feedback cannot reduce the crossover distortion much.
Crossover distortion is at fairly high audio frequencies where their gain and slew rate are low.
Ron H
Joined Apr 14, 2005
7,063
No.
My reply about op amps reducing crossover distortion was intended to answer the OP's question:
Can someone please explain to me how op amps eliminate crossover distortion?
My answer is generally true, but not for all op amps across the audio range. The OP said "eliminate". I changed that to "reduce" in my reply.
I only used LM324/358 as an example of an op amp with internal crossover distortion, and illustrated with a simulation how it reduces internal crossover distortion at low frequencies. I never implied that these op amps were good for audio.
Audioguru
Joined Dec 20, 2007
11,248
The crossover distortion is as high as 3% with negative feedback.
I wonder how high it is without negative feedback. 20%? 40%?
Those lousy old opamps should be buried.
R!f@@
Joined Apr 2, 2009
10,004
What are u trying to prove..opamps are not the one introducing distortion.
the output stage does. Proper biasing minimizes crossover. It never is eliminated.
Even at 0.003% there is distortion. It does not eliminate.
U all are saying cross over. So is the opamp introducing crossover or it's output stage.
Power or no power OPAMP. Class A has NO cross over distortion.
Others even at 0.0000000000000001% crossover distortion.
It is distortion. Difference is it's not measurable or audible.
Audioguru
U said No so many times tht u forgot what it was being said.
Class A has NO distortion.
Everything else has Distortion.
U cannot prove otherwise.
U say NO and u prove ur self wrong.
Ron H
Joined Apr 14, 2005
7,063
I don't disagree with you, except that LM324 is an op amp. The output stage is an integral part of it.
R!f@@
Joined Apr 2, 2009
10,004
By the way.. what does negative feedback has to do with crossover.
I thought feedback is used to stabilize the gain and bandwidth of a typical amp.
Guru is confused with crossover and feedback.
How long have u been a guru in Audio.
I think Ur nick precedes you
Audioguru
Joined Dec 20, 2007
11,248
A few people can hear 0.1% crossover distortion but they cannot hear the 0.003% total distortion from many opamps.
Class-A is a heater, not an amplifier. A class-A amplifier has even-harmonics distortion. A class-AB amplifier cancels most even harmonics distortion.
Most amplifiers are cool class-AB and their tiny amount of distortion cannot be heard.
R!f@@
Joined Apr 2, 2009
10,004
By the way....Class A won't melt at low power and pre-drive stages.
Even at moderate power It works. I have built it and to drive a high frequency to it's best, this is the way to go.
I always prefer class A pre- drive stage to ELIMINATE crossover at this point.
Guru. U are not the only one who built Power amps and is familiar with it's varieties and heating effects
R!f@@
Joined Apr 2, 2009
10,004
AAAH! Now u are getting my point. :)
We are not talking about individual hearing capability.
We were talking about OPAMP eliminating cross-over.
It minimizes. It never eliminates.
Hearing it is totally different.
