All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-08-2010, 02:12 PM
wes wes is offline
Default Bifilar Coil Inductance?
Hello, I have a quick question that maybe someone could answer here.
I know that if you have a Bifilar coil with the winding in a way so that the current goes in the opposite directions then your Inductance of that coil is close to zero (I know it will never reach 0, Impossible )
Now the part I am not sure about has to do with the bifilar coil when wound in series con-fig (I think it is series )
Here is a picture:
http://merlib.org/node/5516
it is the second one.
Would the this configuration have a lower inductance then a standard coil.
My reasoning for this is that since the coils are furthur apart, they would not be affected as much by the current flowing through the coils.
If you follow the flow of the current then you see that it travels withing the coil then exits back out and then goes back into the coil through the second winding?
So would the inductance be smaller or would it be the same as a standard coil or would it be bigger?
  #2
Old 10-08-2010, 02:14 PM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
Good question due to the mutual inductance.
You can compute the inductance of each coil given spacing, etc but two in perfect parallel?
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
  #3
Old 10-08-2010, 06:29 PM
The Electrician The Electrician is offline
Default
When you have a bifilar pair like this, you can measure the inductance of one of the coils, ignoring the other; call that value of inductance L.
Now, if the two coils are connected in series aiding configuration, the inductance will be 4*L.
If they are connected the other way, series opposing, the inductance of the combination will be very small.
The Following User Says Thank You to The Electrician For This Useful Post:
observativetiger (02-15-2014)
  #4
Old 10-08-2010, 07:40 PM
Bill_Marsden's Avatar
Bill_Marsden Bill_Marsden is offline
Super Moderator
Default
Which is why it is used to make resistors as opposed to conductors. All wires have some inductance, and by running next to each other, some capacitance. They also have resistance. The method of winding coils determines what characteristic is the predominant one used.
I'm willing to bet this is off a HHO site, because this quote...
Quote:
Tesla explains that a standard coil of 1000 turns with a potential of 100 volts across it will have a difference of .1 volt between turns. A similar bifilar coil will have a potential of 50 volts between turns. In that the stored energy is a function of the square of the voltages, the energy in the bifilar will be 502/.12 = 2500/.01 = 250,000 times greater than the standard coil!
is utter BS!. A bifilar coil with opposing windings stores no energy, the two opposing coils cancel the ability to store energy out. This is why it is predominately used for resistance. Do resistors store energy?
We have heard the same tired false arguments by all the HHO fans out there before Beenthere put his foot down.
http://www.allaboutcircuits.com/vol_1/chpt_8/12.html
__________________
"Good enough is enemy of the best." An old engineering saying, Author unknown.
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input. Thanks for the verbage Wookie.
Last edited by Bill_Marsden; 10-08-2010 at 08:21 PM. Reason: Added qualification to Bifilar Coil
  #5
Old 10-08-2010, 07:47 PM
kubeek's Avatar
kubeek kubeek is online now
Default
The two coils are not opposing, the current is still circulating clockwise, from A to B. Still I donīt see any point in this configuration apart from some different capacity.
  #6
Old 10-08-2010, 07:48 PM
bertus's Avatar
bertus bertus is offline
Super Moderator
Default
Hello Bill,
You are probably right.
Take a look at post #106 of this thread from the energenicforum:
http://www.energeticforum.com/renewa...hematic-4.html
Lets see what beenthere thinks of it.
Bertus
__________________
You don't have to know everything, if you know where to find it.
When you do ask questions, you may look stupid.
When you do NOT ask questions, you will STAY stupid.
It would be nice to have the Timezone ( GMT +/- x ) in the location field in the profile.
(User CP -> Edit Your Details)
  #7
Old 10-08-2010, 08:17 PM
Super Moderator
Default
Quote:
Look again at the second illustration, one coil is clockwise, the other counterclockwise, thereby canceling the inductance. I'm not sure what the capacitance would be. Overall I think it would have a very complex frequency response.
I thought beenthere would be interested in this thread (there is nothing wrong with it and it violates no rules), so I sent an email pointing it out.
__________________
General info:
  #8
Old 10-08-2010, 08:25 PM
Super Moderator
Default
Here is a picture:
You got it backwards, the first illustration is a true coil/capacitor circuit, the second has two coils in opposition to each other. I have seen it many times from HHO nuts. Tesla actually invented the first as a super simple way to build a resonant circuit. Components have gotten cheaper, so it is pretty well obsolete.
__________________
General info:
  #9
Old 10-08-2010, 09:51 PM
timrobbins's Avatar
timrobbins timrobbins is offline
Default
Have another close look at the winding config guys, and the comment from Tesla - and think about what Tesla was up to!
His bifilar arrangement is configured to purposefully give the opposite 'low inductance' effect that you guys are thinking of.
Imagine applying a step voltage across one of the wires only, and what is generated across the other wire. Analogous to an automotive ignition coil.
Ciao, Tim
  #10
Old 10-08-2010, 10:23 PM
kubeek's Avatar
Default
Quote:
I think you should look again, both coils are clockwise.
Tags
Related Site Pages
Section Title
Textbook Tesla polyphase induction motors : Ac Motors
Worksheet Step-up, step-down, and isolation transformers
Worksheet Mutual inductance
Worksheet Inductors
Worksheet Inductance
Textbook Mutual inductance and basic operation : Transformers
Textbook Special transformers and applications : Transformers
Video Lecture Inductors (Part 1) - Inductors,Capacitors,Transformers
Textbook CMOS 555 LONG DURATION FLYBACK LED FLASHER : 555 Timer Circuits
Textbook Inductor commutating circuits : Diodes And Rectifiers
Similar Threads
Thread Thread Starter Forum Replies Last Post
12V AC motorcycle regulator Suzukiman The Projects Forum 156 06-17-2011 07:19 PM
Simple Ignition Coil Circuit Driver Sirisian The Projects Forum 4 05-15-2010 03:22 PM
Need help with Induction bifilar coil on 3/8 graphite rod, no output electricme The Projects Forum 2 10-15-2008 02:21 PM
Question on mutual inductance mentaaal Homework Help 9 12-31-2007 01:32 PM
Measuring current using inductance coil Parthasarathy General Electronics Chat 2 02-17-2004 01:25 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
