Taurus is an high-end amplifier capable of delivering up to 45W per channel to 4Ohm loads. The project is pretty straightforward: a simple and yet powerful power supply, and both channels built around the LM3875 IC. Although easy to build, this project is far from being recommended to beginners, since it uses the mains. The project eventually can be adapted to work with 115V~: all you need to do is to use a 250VA transformer suitable for 115V~, and a proper primary fuse (the secondary fuses won't change).
List of components:
C1/2/7/8 10mF electrolytic capacitor (50V);
C3/5/9/11 100µF electrolytic capacitor (50V);
C4/6/10/12 100nF polyester capacitor (63V);
C13/14 22µF non-polarized electrolytic capacitor (6,3V);
D1-4 6A05 rectifier diode;
F1 2A fast fuse;
F2/3 - 6,3A slow-blow fuse;
HS1/2 1,2°C/W passive heatsink;
IC1/2 LM3875 audio power amplifier (LM3875TF);
J1 Earthed AC power plug;
J2/3 RCA socket;
JW 26AWG stranded wire;
LP 230V~ resistored neon bulb;
R1 10KR double gang potenciometer (10% tol., 1/8W);
R2/6 4,7KR carbon resistor (5% tol., 1/8W);
R3/5/7/9 1KR carbon resistor (5% tol., 1/8W);
R4/8 33KR carbon resistor (5% tol., 1/8W);
S DPST switch;
T Toroidal transformer 230V~ pri. 2x18V~ sec. 250VA.
Electrical parameters:
- Va min = 207V RMS
- Va max = 253V RMS
- Ia (Va = 230V RMS, Z = 4Ohm) = 991.9mA RMS
- Ia (Va = 230V RMS, Z = 8Ohm) = 686.7mA RMS
- P (Va = 230V RMS, Z = 4Ohm) = 228.1W
- P (Va = 230V RMS, Z = 8Ohm) = 157.9W
Amplification characteristics (each channel):
- Input impedance: 3,197-10KOhm
- Input sensitivity: 500mV RMS
- Gain: 30,63dB (34V/V)
- Frequency response (-3dB): 7.234-120000Hz
- Output power (Z = 4Ohm): 45W
- Output power (Z = 8Ohm): 29W
List of components:
F1 2A fast fuse;
J2/3 RCA socket;
S DPST switch;
- Va min = 207V RMS
- Va max = 253V RMS
