All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 10-03-2010, 11:12 PM
notoriusjt2 notoriusjt2 is offline
Default half-wave rectifier with delay angle
Load power = (2.5^2)*30=187.5
it cant be this easy... what formula should I be using?
  #2
Old 10-03-2010, 11:44 PM
R!f@@'s Avatar
R!f@@ R!f@@ is offline
Send a message via MSN to R!f@@
Default
1920 is the answer
Delay angle or not. A resistor will dissipate power according to the applied RMS Voltage
Formula is P=V^2/R
__________________
R!f@@
\bullet Do not get angry and do not be harsh because you will never regret being kind \bullet
  #3
Old 10-03-2010, 11:54 PM
Default
in the book it gives me these equations....
Vm=Vpeak
then it says to use the P=Vrms^2/R
but it gives me no formulas that have anything to do with current.
are you sure thats still a valid answer?
  #4
Old 10-04-2010, 12:20 AM
R!f@@'s Avatar
Default
Quote:
Vm=Vpeak
What does that equation look like.
Same one I gave u...forget the current. It is their to confuse newbies like you, and it is doing a pretty good job too.
__________________
R!f@@
  #5
Old 10-04-2010, 12:28 AM
Default
haha i gotcha, it is very confusing. that Vrms calculation takes into account for the delay angle. alpha=delay angle
so the delay angle has nothing to do with it? it doesnt even matter?
  #6
Old 10-04-2010, 12:31 AM
R!f@@'s Avatar
Default
Delay angle matters when the load is Reactive, Like Capacitive or Inductive.
Besides, ur Q, says average current.
Average values are not used for power calculation. Didn't u know that?
__________________
R!f@@
  #7
Old 10-04-2010, 02:13 AM
Default
i went with answer 'E' and it was incorrect
i know that delay angle needs to be accounted for somewhere
  #8
Old 10-04-2010, 03:01 AM
R!f@@'s Avatar
Default
shoooooot!!!. I missed the half wave rectifier part..
That was really clumsy of me...
Hold on, let me see
__________________
R!f@@
  #9
Old 10-04-2010, 03:12 AM
R!f@@'s Avatar
Default
Answer is way wrong. Since the AC is rectified we have to find the voltage seen by the load. which is lower than Vrms.
In the formula shows Vo, is any other formula given for Vo
{ed}
Is this q related to practical application. The delay angle is the SCR firing angle to rectify the AC. You have to find out Vo using a scope if this is practical based.
__________________
R!f@@
  #10
Old 10-04-2010, 05:25 AM
The Electrician The Electrician is offline
Default
You must first find the conduction interval that will give an average current of 2.5 amps into a 30Ω resistor.
Having found that conduction interval you then integrate instantaneous product of voltage and current over the conduction interval. That will give you the power absorbed by the resistor.
Alternatively, having found the relevant conduction interval, you could calculate the RMS value of that voltage coming out of the controlled rectifier, and use that value in the familiar formula P = E^2/R. The result is the same.
The first attached image shows the details. The second shows the RMS calculation mentioned in the paragraph above.
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with 3 phase and 6 phase half wave rectifier darthfader Homework Help 1 12-19-2009 07:01 AM
Full Wave Vs. Half Wave Rectifier at Small Voltages rperea General Electronics Chat 5 07-26-2009 09:07 PM
Half wave controlled rectifier in simulink/matlab - Thyristor gate angle? Nuoz General Electronics Chat 4 02-26-2009 04:45 PM
Purpose for Components in Half Wave rectifier? lsecrease General Electronics Chat 3 09-18-2008 05:12 PM
Half wave rectifier strathy General Electronics Chat 19 03-27-2008 10:06 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
