Bandwidth of square wave
EngIntoHW
Joined Apr 24, 2010
143
In communcation, data signals carry square waves which represent symbols.
The fourier transform of a square wave is sinc.
1. Does it mean that the fourier transform of a data signal (which is a sequence of time-shifted square waves) is a sum of phase-shifted sincs?
2. How can I find the spectrum (bandwidth) of a 1Mbps rated data signal?
Thank you :)
Nik
Joined May 20, 2006
55
Well, if you have really square ('fast') edges, your pulse train will smear across a wide spectrum. I suppose you could deconstruct it into a *very* long series of harmonics...
Ghar
Joined Mar 8, 2010
655
For 1) I guess that has to be correct but I've never thought of that way.
If you repeat a waveform in the time domain you are sampling it in the frequency domain.
So if the spectrum of a square pulse is a sinc, the spectrum of a square wave (wave implies repetition) is a set of defined harmonics following a sinc envelope.
The bandwidth of a square wave is technically infinite so you need to come up with some definition to compute a value.
Finite rise and fall times add an extra decaying coefficient to the sinc function making upper frequency harmonics fall off faster. The bandwidth is still technically infinite... sometimes you'll see it defined as the corner frequency where this rise/fall time coefficient begins to work.
For rise time = fall time = tr, that's given by:
\(f = \frac{1}{\pi t_r}\)
Anyway, this infinite bandwidth problem is why you don't actually use square pulses in wireless digital communication.
http://en.wikipedia.org/wiki/Pulse-shaping
http://en.wikipedia.org/wiki/Raised_cosine
