See figure attached for problem statement, and other figure for my attempt.
In my attempt I was able to successfully draw, and use Karnaugh maps to simplify my two functions f and g significantly.
However, the part I get stuck on is, how do I know what can be shared between f and g in a combined circuit?
I attached the solution given for this problem in another figure. As I said above, I can get the first part of the solution without a problem, it's just the jump to the combined circuit that I'm confused about. I can't see how he gets there.
I mean, sure I could start using boolean algebra and try see what's being shared between f and g after simplifying it, but then if I miss something I'm screwed.
Is there a systematic process for finding terms that can be shared between f and g? I feel like I'm left in the dark on this one.
Hopefully the source of my confusion is clear. (If not, just say so and I will try to further clarify)
Any ideas/suggestions/tips/hint/advice/strategies you have for me would be greatly appreciated!
Thanks again,
Thanks again,
