All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > General Electronics Chat
Notices
General Electronics Chat Discussion forum for general chat about anything electronics related, including asking questions about material in the All About Circuits E-book, Worksheets, and Videos.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-23-2010, 01:09 AM
bassplayer142 bassplayer142 is offline
Member
Default Time Delay Fuse for DC Motor
Does anyone have any information about time delay fuses in series with a DC motor for protection against over current. If a DC motor is rated at 32 Amp stall current, what value of a fuse should I have? 30 Amps? An H-bridge I'm looking into is rated at 20Amps continuous with 30Amp peak.
Any help is greatly appreciated. Thanks in advance!
  #2
Old 09-23-2010, 01:21 AM
sgardner025's Avatar
sgardner025 sgardner025 is offline
Member
Default
You may want to look at a bridge that will handle more current, or use individual mosfets and use a h-bridge driver ic. Another thing you may want to look into is using current sensing and the associated control methods instead of time delay fuses. What are the motor specifications and what type of control do you need (what will the motor be used for)?
The Following User Says Thank You to sgardner025 For This Useful Post:
bassplayer142 (09-23-2010)
  #3
Old 09-23-2010, 01:40 AM
Jaguarjoe Jaguarjoe is offline
Default
This might work for overload protection:
http://www.sensata.com/klixon/motor-protector-6ap.htm
They will give you free samples, so if you only need one, you'll be all set.
sgardner025 is right- you need a heftier bridge if you want trouble free operation.
The Following User Says Thank You to Jaguarjoe For This Useful Post:
  #4
Old 09-23-2010, 01:46 AM
t_n_k t_n_k is offline
Default
You would probably better focus attention on protecting the power semiconductors rather than the DC motor - which in terms of over-current is a fairly robust device in comparison to a semiconductor switch.
Normal practice is to use fast acting fuses for semiconductor protection so using time delay fuses may not be desirable. Perhaps a combination of the two types is required. Alternatively, graded motor protection might be accomplished with an adjustable thermal overload relay of some sort. Depends on your budget and the degree of 'sophistication' required.
The Following User Says Thank You to t_n_k For This Useful Post:
  #5
Old 09-23-2010, 02:46 AM
Member
Default
Thanks for the prompt and helpful replies! I will need to power two motors to drive a tank style robot up a stairs at a 32deg angle. The robot will probably be 20+ lbs.
The type of motors I am looking at are below with a large gear ratio for higher torque. The H-bridge I am looking into is also shown below. The protection circuitry is just extra stuff to make sure I don't burn anything from mistakes. I haven't decided on a power supply yet so just neglect that for now.
http://www.robotmarketplace.com/products/0-HG312.html
http://www.robotshop.ca/cytron-10-30...ontroller.html
  #6
Old 09-23-2010, 03:09 AM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
A lot of the power window circuits on automobiles utilize a very fast overcurrent switch on the driving motor.
Then there are Polyfuses, they work pretty well too.
http://www.littelfuse.com/data/en/Pr...lyfuse_PTC.pdf
Most standard motor protectors for AC are built into the motor starters themselves and operate both via a magnetic overcurrent and a thermal heating strip. The heating strips are interchangeable to match the motors.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
The Following User Says Thank You to marshallf3 For This Useful Post:
  #7
Old 09-23-2010, 03:44 AM
GetDeviceInfo's Avatar
GetDeviceInfo GetDeviceInfo is offline
Default
Code calls for a 150% FLA rating, be it time delay, non time delay, or circuit breaker.
The Following User Says Thank You to GetDeviceInfo For This Useful Post:
  #8
Old 09-23-2010, 11:21 AM
Default
There's code for toy robot motors?
  #9
Old 09-23-2010, 11:50 AM
Default
Sorry, missed the hobby robot thing.
  #10
Old 09-23-2010, 12:17 PM
SgtWookie's Avatar
SgtWookie SgtWookie is offline
Expert Member
Default
The driver unit you're considering most likely contains a VNH2SP30-E IC, which is a fully integrated H-bridge motor driver with PWM.
Datasheet: http://www.st.com/stonline/books/pdf/docs/10832.pdf
It will likely be one of the most compact and low weight solutions that you'll find; both pretty important considerations for a robot - not to mention the relative simplicity of integration.
Marshallf3's Polyfuse suggestion is a very good one. Compact, inexpensive, and automatically resets. You could also use an automotive-type circuit breaker, but it would be larger, heavier, and likely more expensive.
__________________
General info:
If you have a question, please start a thread/topic. I do not provide gratis assistance via PM nor E-mail, as that would violate the intent of this Board, which is sharing knowledge ... and deprives you of other knowledgeable input.
Tags
Related Site Pages
Section Title
Worksheet Time-delay electromechanical relays
Worksheet Superposition theorem
Worksheet AC motor control circuits
Textbook Synchronous Motors : Ac Motors
Worksheet DC motor control circuits
Worksheet Overcurrent protection
Textbook The Silicon-Controlled Rectifier (SCR) : Thyristors
Video Lecture Electronic Components A - Basic Components and Technical Notation
Textbook Contactors : Electromechanical Relays
Textbook Fuses : Physics Of Conductors And Insulators
Similar Threads
Thread Thread Starter Forum Replies Last Post
Time Delay For Solid State Relay?(CONTACTOR) aq_rules The Projects Forum 11 01-26-2010 12:16 AM
Time delay circuit davidw General Electronics Chat 16 01-08-2010 04:07 PM
making PWM speed controller for Electric bike CaptainPrice The Projects Forum 41 09-25-2009 08:09 PM
simple time delay switch- 555 or simple rc network with transistor devalvyas General Electronics Chat 16 06-24-2009 02:39 PM
time delay relays Ericeugene General Electronics Chat 2 11-07-2008 05:04 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
