All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-22-2010, 09:28 PM
jegues's Avatar
jegues jegues is offline
Question Boolean Algebra, equivalent expressions
Problem Statement: Using Boolean Algebra, determine whether or not the following expressions are valid:
I don't even know how to start questions like this. I'm not too bad in boolean algebra however when I'm doing a questions as complicated as this it's overwhelming.
I can't formulate an attack plan with an equivalent of this complexity, I feel like I just have to start adding terms that are equivalent to 0 and try to reduce to the RHS somehow.
How can I plan out my attack so that I have more of a chance of turning the LHS into the RHS? What specific characteristics or hints do you look for?
Thanks again!
  #2
Old 09-22-2010, 10:43 PM
Georacer's Avatar
Georacer Georacer is offline
Super Moderator
Default
Even though it's downright calculative, why don't you try to make the truth tables of the two expressions? They 're only 8 rows long and will definitely nail that problem.
However, if you want to stay true to the essense of the exercise and use boolean algebra, you can "disguise" a truth table into a sum of its terms, and then see wich terms appear on each side.
For example,
which clearly shows that this term contains minterms 3 and 1 (taking x3 as the Least Significant Bit).
I think this is the most strategic, fool-proof and thought-free attack plan you can use.
__________________
I am a prisoner of high standards and low social skills
____________________________________
I wish I was the best at what I would do, and what I would do wouldn't be pretty.
  #3
Old 09-23-2010, 01:23 AM
jegues's Avatar
Question
For example,
Okay so here's my attempt at disguising a truth table in my boolean algebra expression for the LHS. I came up with the following,
With x3 being the least significant bit one can see that the following binary values will represent a 1 in our truth table,
011,
001,
110,
011 (repeated),
010,
101,
100.
I don't how I can use this information to turn the LHS into my RHS.
I could expand my RHS in terms of minterms as well and show that the truth tables are the same, but the questions asks me to use boolean algebra.
Any ideas?
EDIT: I figured it out. I do exactly what I stated above. Do what I just did to LHS to RHS now, and then I'll see that both terms contain the exact same terms, and therefore they are equivalent.
  #4
Old 09-23-2010, 12:01 PM
Georacer's Avatar
Super Moderator
Default
You got it! And remember that duplicate terms can be simply ignored.
__________________
  #5
Old 09-23-2010, 06:55 PM
jegues's Avatar
Default
Right!
Because after all,
Tags
Related Site Pages
Section Title
Worksheet Sum-of-Products and Product-of-Sums expressions
Worksheet Boolean algebra
Worksheet Karnaugh mapping
Video Lecture Completing Truth Tables - Digital
Textbook Minterm vs maxterm solution : Karnaugh Mapping
Textbook Karnaugh maps, truth tables, and Boolean expressions : Karnaugh Mapping
Textbook Converting truth tables into Boolean expressions : Boolean Algebra
Textbook The Exclusive-OR function : Boolean Algebra
Textbook Circuit simplification examples : Boolean Algebra
Textbook Boolean arithmetic : Boolean Algebra
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help with Boolean algebra bigga Homework Help 3 08-12-2010 12:26 PM
Boolean Algebra captainjapan Homework Help 2 10-22-2008 11:34 PM
Boolean Algebra (Simplification?) kazafz Math 7 08-14-2008 01:53 PM
Equivalent Boolean Expressions, need help proving. azngeek Homework Help 2 07-22-2008 11:11 AM
I need help in boolean algebra? HMHQ8 Math 7 01-31-2008 04:17 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
