All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #11
Old 09-22-2010, 07:11 PM
Papabravo's Avatar
Papabravo Papabravo is offline
Default
You can also use an integrator to convert a sine to a cosine. If you have a choice between an integrator and a differentiator you should always choose the integrator.
__________________
We never have time to do it right,
But we always have time to do it over.
  #12
Old 09-24-2010, 05:38 AM
JoeJester's Avatar
JoeJester JoeJester is offline
Default
The OPs component's values failed to follow the Application Note.
Consider this simulation using the TLC 2201 and the Application Note:
__________________
Joe
http://www.fcctests.com
  #13
Old 09-24-2010, 10:19 AM
t06afre's Avatar
t06afre t06afre is offline
Default
Perhaps it would be more easy for you to create a "quadrature oscillator" such an oscillator give out a sine and cosine wave.
  #14
Old 09-24-2010, 04:36 PM
dayalrohan dayalrohan is offline
Default
Not sure what I did wrong,
R2C1 = designed to give 0 dB gain at fc=10 Hz, hence their values. fh is a order higher. Can you give me your designed values?
Also I get correct results in my simulations as well (I use LTspice).
I was thinking of an integrator, but the output will have a DC bias equal to the supply voltage, getting rid of that bias is going to be difficult at such a low frequency. I can use a RC type load I guess to chop off that DC and get that AC on the R load.
I am inclining towards a quadrature type oscillator myself; havent made one ever, does the signal come out nice practically ( I mean distortion free).
Also
@tom66
Removing the compensating components (non-essential), I just increase the noise in the output but the distortion remains.
  #15
Old 09-24-2010, 06:42 PM
JoeJester's Avatar
Default
According to the application note ... fc = 10f and fh = 100f (both formulas) f (10 Hz) will be -20 dB.
__________________
Joe
  #16
Old 09-25-2010, 09:45 AM
DickCappels DickCappels is offline
Default
From the distortion, it looks like the output of the opamp is capacitively coupled to the non-inverting input, causing hysteresis. Try grounding the noninverting input instead of returning it to ground through a resistor, and that would solve the problem if its coupling via stray capacitance. I think you can get away with leaving R3 out of the circuit because the input bias currents on the inputs of the TLC2201IP are very low.
Other than the stray C, the circuit as you show it is fine.
  #17
Old 09-28-2010, 02:20 AM
Default
Well, I tried that as well. As far as I could see, no appreciable change. My simulation runs fine, so it must be something on BB (practical) that is skewing up things. In fact, I coupled a capacitor as high as 100 pF between non-inverting input and output but could not see the same result in simulation.
I tried other options like:
1. Integrator - too much phase delay in my range ( 2-30 Hz)
2. Quadrature oscillator circuit - too much noise, resembles a triangular wave rather than a sine wave.
Any help or any other circuit to convert sine to cos would be really appreciated
  #18
Old 09-28-2010, 03:59 AM
Default
That brings us back to crossover distortion. Is your power supply voltage adequate? Sometimes crossover distortion is helped by a load resistor to ground.
  #19
Old 09-28-2010, 02:00 PM
Default
Already tried that long time back (I mean loading),
supply is nice, have checked it on oscilloscope for any ac ripple. (I am using +/- 5V)
Even tried a generous offering of bypassing capacitors at the + and - supply near the op-amp.
I thought this was going to be done in 10 minutes, boy was I wrong
Tags
Related Site Pages
Section Title
Worksheet Phase-locked loops
Worksheet Passive integrator and differentiator circuits
Worksheet Mixed-frequency signals
Textbook AC instrumentation transducers : Ac Metering Circuits
Textbook Circuit effects : Mixed-frequency Ac Signals
Textbook More on spectrum analysis : Mixed-frequency Ac Signals
Textbook Other waveshapes : Mixed-frequency Ac Signals
Textbook Square wave signals : Mixed-frequency Ac Signals
Textbook Introduction : Mixed-frequency Ac Signals
Textbook AC waveforms : Basic Ac Theory
Similar Threads
Thread Thread Starter Forum Replies Last Post
Sine Wave to Square Wave converter retaining original P-to-P jarek319 General Electronics Chat 18 09-01-2010 11:20 AM
solar cell dc converter to move car motor kh81hk Homework Help 4 03-21-2010 02:34 PM
Sine to Square Wave Converter @ 10MHz youknowwho6996 General Electronics Chat 3 09-05-2009 02:35 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
