All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > Homework Help
Notices
Homework Help Stuck on a textbook question or coursework? Cramming for a test and need help understanding something? Post your questions and attempts here and let others help.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-18-2010, 04:21 AM
JeromeDarshana JeromeDarshana is offline
Junior Member
Red face Cascade Amplifier
hi i need to make an amplifier which has
gain of 15
output impedence of 30 Ohm
input Impedence of 30 kOhm
this must be a cascade amplifier.
can some one explain how to do the calculations ??
i need all the formulas and the was how they determine
  #2
Old 09-18-2010, 04:44 AM
Ghar Ghar is offline
Default
Don't make duplicate threads.
Formulas go with schematics, you have no schematics.
  #3
Old 09-18-2010, 05:07 AM
retched's Avatar
retched retched is offline
Default
Here is the section of our ebook that pertains to cascode amps:
http://www.allaboutcircuits.com/vol_3/chpt_4/8.html
Read. Read. Read.
The book starts here:
http://www.allaboutcircuits.com/vol_1/index.html
__________________
-rm-
  #4
Old 09-18-2010, 02:36 PM
Audioguru Audioguru is offline
Banned
Default
He doesn't want a cascode amplifier. He wants to cascade amplifiers or he doesn't know how so spell correctly.
  #5
Old 09-18-2010, 02:38 PM
retched's Avatar
Default
Jeez a wheez.
Please forgive me. I read it incorrectly. (Or hopefully im psychic and he spelled it wrong )
__________________
-rm-
  #6
Old 09-18-2010, 04:16 PM
Junior Member
Default
i need cascade amplifier not cascode :P
  #7
Old 09-18-2010, 04:45 PM
Banned
Default
Did you look at the cascade amplifiers in Google?
They are simply one amplifier that is amplified by another amplifier.
The gain is only 15 so it should be easy. The first stage can be a common-emitter transistor.
The output impedance is very low so it should have an emitter-follower or a pair of complementary (NPN and PNP) emitter-followers as the second stage.
The input impedance is fairly high at 30k so the first transistor should have a fairly low current and an emitter resistor to increase the input impedance and reduce the gain.
Tags
Related Site Pages
Section Title
Worksheet Counters
Worksheet Class B BJT amplifiers
Worksheet Class A BJT amplifiers
Worksheet Elementary amplifier theory
Worksheet Impedance matching with transformers
Worksheet Decibel measurements
Worksheet Series-parallel combination AC circuits
Textbook Amplifier impedances : Bipolar Junction Transistors
Textbook The cascode amplifier : Bipolar Junction Transistors
Textbook Attenuators : Amplifiers And Active Devices
Similar Threads
Thread Thread Starter Forum Replies Last Post
BJT Cascade amplifier w/ temperature consideration.Homework for school. electrogirl Homework Help 12 05-13-2010 11:00 AM
Help regarding audio amplifier.. sarang2502 General Electronics Chat 16 04-27-2010 10:16 PM
help bjt amplifier cascade and AO albertgil1989 Homework Help 1 04-22-2010 05:21 AM
Constron of a cascade amplifier using the lm324 Kango General Electronics Chat 3 10-13-2007 07:25 AM
Dimension of a cascade amplifier Kango Homework Help 4 10-08-2007 09:01 AM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
