Why simple transistor (ex. Bc 558 ) have emitter -base region more doping (low resistance) and in big transistor ( 2n3055) have collector -base region more doped (low resistance) pls reply...!
Thank's in advance.
Thank's in advance.
Because they have to make them that way to work. (and if you'd think about the way a transistor works it would make sense anyway)Why simple transistor (ex. Bc 558 ) have emitter -base region more doping (low resistance) and in big transistor ( 2n3055) have collector -base region more doped (low resistance) pls reply...!
Thank's in advance.
You need more basic knowledge of how things work first. You are seeking knowledge of things you do not understand, and the answers only make you ask more questions. If you had a basic understanding of the subject the answers you are being given would provide insight. Instead they confuse you and cause you to ask more and more questions, whose answers confuse you and make you ask even more questions.I don't get my answer.
the output seen in cro was not perfect
I think you should go see a doctor, ask him about schizofrenia...Sir, i don't have CRO to see waveform...!
man, i have seen output in college lab in cro, at home i don't have cro...!I think you should go see a doctor, ask him about schizofrenia...
How does amplifier oscillate, i am not understanding??By stability they mean it is less likely to oscillate under normal operating conditions.
