how to design an inductor
Sakwiti
Joined Sep 7, 2010
I want to get 10 amp. load at 170v from 230v domestic supply to feed a heating element that I have fabricated. Going to a step down transformer is a tiresome job. difficult to find a big core, much enameled wires. Instead I decided to use a big iron core inductor in series with the element to reduce the excess 92v. What I have to do is fabricate an inductor of which impedance is about 9.2Ω. This circuit contains a SSR to control the load to the element and the SSR receives on/off signals from a digital temperature controller.
Will this system work? If it work, Will the phase shift at the inductor affect the performance of SSR? What is cross sectional area of the iron core suitable for this inductor. Should I use a big enameled wire to wind the inductor enough to deliver 10 amps?
Can I use a triac based power controller to reduce the voltage? Will this power controller affect SSR ?
Papabravo
Joined Feb 24, 2006
21,225
Doesn't matter. This kind of circuit cannot be made safe and so it will probably be quickly banned by the moderators. The importance of using a transformer cannot be overstated. If not for yourself then for the unaware who may come into contact with the device now or in the future.
marshallf3
Joined Jul 26, 2010
2,358
Yea, don't go messing about with the line voltage end. A large capacity light dimmer by itself might be your best shot.
beenthere
Joined Apr 20, 2004
15,819
It would seem that the load is not properly designed. At any rate, homemade ballasts are not likely without an iron core.
A big dimmer may be your best way to control power.
marshallf3
Joined Jul 26, 2010
2,358
Really is no choice. Trying to eat up that amount of power with a choke is kind of crazy, it would have to be a monster to hold up to the load and what's it going to do? Put out heat anyway.
Wendy
Joined Mar 24, 2008
23,421
Thing about a choke, they don't dissipate power. They use reactance to resist current flow, which does not generate heat like a resistor. This is why they are used as ballasts for fluorescent lights.
Ghar
Joined Mar 8, 2010
655
I don't know what you'd gain, the inductor would still need a gigantic iron core to be able to support the large voltage and current without saturating.
SgtWookie
Joined Jul 17, 2007
22,230
Not just iron; it would need to have high silicon content, and to have many layers to minimize eddy currents.
Core material for transformers is rather specialized stuff. You can't just walk into your local hardware store and buy it. If you tried to use something like a portion of an old cast-iron automotive engine block, you would wind up with horrific losses due to eddy currents.
marshallf3
Joined Jul 26, 2010
2,358
Perfect inductor yes, normal one with eddy current losses no.
I'm still for the light dimmer and would probably prefer one that was rated to control inductive loads whether or not the heating element was as they tend to be toughter in design. He's also going to need one rated to work with 240V devices.
