Thanks for the reply " beenthere" ... Iam not able to use the thread anymore as a closed button has replaced the reply button, so iam posting on a new thread . I hope the moderator can help me with this.
All right , thats a start for improving the circuit . iam going to put in a isolation transformer on the " line in " and i have modified the original circuit.
Further i found a circuit which looks fairly simple to build and the output is a square wave with pulse width and frequency control. Any comment on the circuit and if i can get 10-200hz output control with it.
Further , my original questions
1) Can use this pulsing circuit as the input for the DC SSr ??
2)What exactly need to be the value of inductors for an electrolysis load of max designed load 15amps , 200V dc.
Thanks for the help again,
Bhargav
Quote from original post ********************************
Hello Group,
I have a 200V 15 amps DC CVCC benchtop power supply. Iam trying to develop a electrolysis system and i require 10-200hz adjustable squarewave pulsed dc. { worst case 200 hz fixed }
As this is for a electrical type of power supply , i do not need high precision on the square waves . This is the idea i have till now for the power supply .
Line Ac --Isolation transformer -- DC rectifier -- DC Capacitor --DC SSR-- Inductor -- Load
DC pulsing circuit
As iam not a professional electrical engineer and i cant get any local company to take up development of the power supply for a single number requirment , iam stuck for over 1 year trying to get professional help. With frustration , iam trying to build my own and i really need help on putting exact numbers on the circuit components. Please help me ...
1) What should be the output of the pulsing circuit to generate square waves on the output of SSR?? will something of this sort work " http://cgi.ebay.com/ebaymotors/Const...Q5fAccessories "
1a) Is there any place where i can buy any standard square wave pulsing circuits on the net ?? any links will be veyr helpful
2) How do i go about fixing a value on the inductor ? The load is an electrolysis system which behaves like a resistive load . Max designed operating parameters are 15 amps , 200 V dc.
Any other precaution i need to take , like maybe a diode somewhere??
If anybody wants to help even professionally , i would be very grateful , please message me at <snip> ( please replace dot with . )
Regards,
Bhargav
end quote ****************************
Bhargav
Hello Group,
DC pulsing circuit
Regards,
Bhargav
