All About Circuits Forum
Go Back   All About Circuits Forum > Electronics Forums > The Projects Forum
Notices
The Projects Forum Working on an electronics project and would like some suggestions, help or critiques? If you would like to comment or assist others with their projects, this is the place to do it.
Reply   Post New Thread
Thread Tools Display Modes
  #1
Old 09-10-2010, 11:16 PM
maverik007 maverik007 is offline
Junior Member
Default Underwater communication
Hi everyone,
I am looking for a communication module that would allow to underwater robots to successfully carry out full-duplex communication for coordinated tasks.
Any suggestions would be greatly appreciated. Btw, I am looking for a comm module that can be interfaced with a PIC microcontroller.
Thanks in advance for your help.
  #2
Old 09-11-2010, 01:50 AM
marshallf3's Avatar
marshallf3 marshallf3 is offline
Location: Oklahoma City, OK. Large enough to be modern but plenty of country left around it.
Default
Submarines used very, very low frequency RF.
__________________
The very first course in engineering school should be how to use Google and Wikipedia
I very often misspell or miss things while making posts so come back and double check a few times.
I also have a full time job and often 10 projects going on at the same time so I'm not always online.
  #3
Old 09-11-2010, 01:56 AM
beenthere's Avatar
beenthere beenthere is offline
Default
Are you looking for audio? - http://en.wikipedia.org/wiki/Underwater_telephone
If not, a blue-green laser may give better range, especially if both tranceivers are going to be submerged. Otherwise things get big and power limited - http://en.wikipedia.org/wiki/Very_low_frequency
__________________
First comes the hardware, then the software.
  #4
Old 09-11-2010, 02:20 AM
Dyslexicbloke Dyslexicbloke is offline
Send a message via Skype™ to Dyslexicbloke
Default
There is a list of diver com system here:-
http://ieeexplore.ieee.org/xpl/freea...number=1090687
The modern ones are almost all modulated sound carrier, something well above human hearing.
If you used light wouldnt it have to be omny directional or at least on a narow plane.
Whats the range / depth / water quality / background noise profile?
Al
  #5
Old 09-11-2010, 07:23 AM
Junior Member
Default
Al
Interesting paper! Thanks for the link The target application is comm between two robots underwater, operating in dirty water (muddy etc) ... can't use opitical comm due to dispersion problems. I was considering finding some sort of a "tag" used to track fish, that's usually used for communicating with hydrophones floating in the water, but these send pre-determined information to the hydrophone receiver. I'd love to have control over the data that's transmitted to allow information exchange between robots (in addition to the tag-identifier that's sent by default)
  #6
Old 09-11-2010, 07:24 AM
Junior Member
Default
Yes, I am looking for audio, as light would be infeasible in muddy environments (like a swamp)
  #7
Old 09-11-2010, 09:10 AM
Default
Another thought ... have you looked at ultrasound?
I dont know anything about it but I do know it only works through a relativly dense fluid because thats what babys float arround in.
Just pondering
Al
  #8
Old 09-12-2010, 03:35 AM
windoze killa windoze killa is offline
Default
What DB said. Ultrasonics is probably the easiest to use. It will be a pretty slow comms link but it would work. Most ultrasonics are around 40Khz. Doing some sort of digital frequency modulation would be the simplest method if you can find some that can have their output frequency changed. You could have say 38Khz for a "1" and 42Khz for a "0". Something to think about.
__________________
Eddy Current is a little dizzy over Milli Volt.
  #9
Old 09-12-2010, 10:53 AM
Junior Member
Default
Quote:
That's an interesting point. I think I might be able to do something in that direction. I'll read more about it and get back with my observations and questions. Thanks
  #10
Old 09-12-2010, 10:55 AM
Default
I am just guessing here but shouldnt you be able to utilise ON / OFF pulses of sound just as you would use a modulated IR system.
ThE the pulses would have to be much furtrer apart because of the time taken to reach their destination but I cant help wondering if an exiating coding system couldnt be used as a basis for your project.
Your biggest issue will be protocol selection, or design ....
Both / all your equipment needs to know its on line (Capable of talking and recieving) all the time.
I recomend you look at two line and single line transmition protocols RS485 / IC2 / Modbus..... the list go's on, but you will want a simple one with a low overhead.
IE not too much header info in the packet and variable block length.
This is because you only have a single conductor, the water, you will have to have some concept of master-slave or master-master architecture that has a flow control strategy to manage when devices Talk, Listne, or decide they recieved or transmitted an error.
Granted you will probably find that most protocols you find couldnt be implimented over a connection that is both slow and has a variable transmition delay but I expect you could take one as a model and then impliment it with a modified timing structure that suites your medium.
You may be able to impliment a protocol with more than 1 transmission line RS232 for example just very slowly, but that would intail diferent modulations for each line and complicate the detectors somewhat. That said it would be faster by some margin.
You could relativly easily design your own protocol but I recomend looking what is availlable now so you understand the challanges and potential solutions.
I find this whole concept interesting and would apriciate your sahring your progress with me if you wouldnt mind.
Al
Tags
Similar Threads
Thread Thread Starter Forum Replies Last Post
Serial communication over 300ft in an aircraft dmusoke The Projects Forum 10 01-14-2010 08:54 PM
Effective Business communication Asad1 Off-Topic 6 02-16-2009 04:38 PM
Serial communication vs Parallel communication Reshma Computing and Networks 16 06-28-2008 04:15 PM
What is RS 485 communication MGP Computing and Networks 2 02-22-2008 07:51 AM
5V to 3V communication BladeSabre Embedded Systems and Microcontrollers 7 11-27-2006 06:18 PM
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
User-posted content, unless source quoted, is licensed under a Creative Commons Public Domain License.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
